Question about Epson Stylus Photo R320 InkJet Printer
Not printing the color indications seem to be o.k, but it does not print at all. Nothing. I checked the alignment, nozzel clean up, nozzel check, anything that needed to be done. still nothing. need help and this has been going on for a long time. thanks
  • sonicnation Oct 09, 2008
    It looks like printer is printing ok but inkks are invisible (( Maybe dara cord, connecting to the head can be damaged? or in such case there woldh have been certain indication?
    Sergeant:
    Champion:
  • 289 Answers
It need to replace the printer heads
Posted on Nov 06, 2011
  • Epson Master
  • 705 Answers
If the machine goes through the motions of printing i.e. it pulls in the paper and the head runs back and forth but put no ink on the page then it would suggest either a fault with the pump cap and/or the pipes from it to the waste pads OR that the heads are clogged.
If you have no flashing warning lamps and the ink loss was gradual over say a page or after the machine has stood for a while, then you should try an under head cleaning routine as in some of my earlier posts. like this one http://www.fixya.com/support/t137335-problem_print_outs_from_printer
If the ink loss was sudden - like after changing the inks, have you checked to see that  you have removed any and all sealing tapes. You do not mention if you are using genuine inl or compatibles. If using compatibles I would try the cleaning cycle first to clear the dried crud from under the head. Ever wonder why Epson do not make cleaning cartridges but almost ALL compatible ink manufacturers do?
Try the cleaning and let me know how you get on
Posted on Oct 10, 2007
SOURCE:
Will not print on paper
if the cartridges were out of the printer for any length of time the ink has dried up on the print heads. you most likely will have to replace the ink cartridges. then allign again before it will print correctly
Apr 04, 2010 | Lexmark JetPrinter Z22 Color InkJet
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Epsonr220 does not print megenta or light megenta colors
The problem seems to be the printhead nozzels are plugged or burntout. I beleive on the Epson, to remove the printhead for cleaning, you must partially disassemble the printer. If you are not up for this, Quit here. If you game, remove the cartridges and tape over the outlet and air hole of each. I find electrical tape the best. Tape snugly but not too tight and once around the cart. If you have a digital camera or a webcam, take photos along the way to help in re-assembly. Remove the drive belt and disconnect the guide rod the printhead slides on at each end. Try and remove the guide rod and print head as one unit. Use alcohol and/or water to clean the print head nozzels, or completely wash the print head with running water. Blow it off and let dry. Put the guide rod back in the print head and put that assembly back in the printer. Attach the guide rod at each end then put the belt back in place. Put the cartridges back and do a nozzel/print head check. If the printer works completely, then you are set. If the magenta still doesn't work, the nozzels may be burnt out. I don't think you can get Epson Print heads, That means a new printer. Lastly DO THIS AT YOUR OWN RISK. I can't even guarantee my work!
May 28, 2009 | Epson Stylus Photo R220 InkJet Printer
Color intensity= poor
Shake the cartridges well, it seems that they become dry, try to replace them and check again, go to driver there is setting makes u clean and test the nozzels which makes the color more rich and at the same time it check the state of the cartridges.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 11, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp K80 printer
I cleaned the vertical centerpost (you'll see it when the cartidge is out)with a small amount of acetone (nail polish remover) on a Qtip & it works fine now....must be some kind of circuit that needs to be closed and the ink on it kept it open....
Dec 19, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
Printing incorrect colouring
plz check the color carts: are they inserted at the right place? If not, change them into the right place. Run the cleaning cycle 4 times to get the wrong ink out of the tube and nozzels.
If you have them at the right places print a test print by pressing ink button and selecting the test print.
Does it look good or do still have the diffrent colors?
Nov 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printing light colors does not work
You RINSED the printhead???
I wouldn't do that again.
Try taking a damp cloth and dabbing it against the printhead nozzels until you get lines forming on the rage from the ink (the nozzels you're having trouble with specifically).
Erice
Oct 29, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
HP 2210 xi printing problem - alignment
Try your question here http://www.techsupportforum.com/hardware-support/printer-support/49664-hp-psc-2210xi-problem.html
May 14, 2007 | HP PSC 2210 All-In-One InkJet Printer
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus Photo R320 InkJet Printer Logo
154 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
