2006 Honda Odyssey Logo
Posted on May 03, 2009
How to enter the unlock code on the 6 disk cd changer
We have a 2006 Odyssey with a 6 disk CD changer that is currently showing "CODE" when powered on. We have the stupid code, but of course, Honda conveniently omits the instructions in the owners manual! What is the power on sequence, and button presses needed to be able to enter the code?
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on May 04, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
49333
Points
33
Look on the side of the glove compartment, there is a sticker with numbers, that is your code. In general, the number from 1 to 6, so you simply enter your code by using the existing buttons.Hope this help.
1helpful
My odyssey 2003 is showing code err for the entertainment
Does the radio work at all. or is the cd player the only issue.? most of the time you need to enter a radio code to unlock the radio. If you enter it wrong to many times it will display error on the display.if you dont know the code then you can call the dealership and get the code after you do the following below to get the serial number.
Press and hold 1 and 6 on the radio while still holding the 1 and 6 press the power button. At this time it will read off serial number
SOUTHERNELECTRONICS.COM
3helpful
2answers
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
1helpful
2005 Expedition - Changed battery and Cd changer won't work now, is there a fix?
I am not familiar with the 2005 Expedition CD changer, but many of the higher end devices require a code to be entered when the power is disconnected. This helps reduce the theft of car audio equipment since it can not be used again until the correct code is entered. Ford dealership can either enter the code for you or look up the code if you do not have the original manual for the CD changer which should have the code written somewhere in the first couple of pages.
My 6 disc cd changer won't read cds
unplug the power to the cd player for about 10 minutes or so. usually that reqiures unhooking the car battery. if that radio is of the anti-theft variety make sure you know the code and how to enter it before you remove power
Same problem -05 Odyssey CD changer jammed/broken
you can easly do it you self u will just need a radio code to enter when u r all done so done forget to right down the numbers on the radio u r putting in and call ur local honda dealer for the code
2helpful
2answers
HOW TO UNLOCK RADIO 4 AUDI A6 1999
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. This will cause the radio to consider the number 1000 to be the input code.Use station buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
I have a 2006 Yukon xl Denali with the Bose radio/ Navigation and separate 6 disc cd changer. The am/fm radio works fine, but when using XM, the channels get stuck and have to be turned manually.
generally it would just need to be reset... unhook the battery for about ten minutes and hook it back up. make sure you have the unlock code for the radio FIRST and you know how to enter it.
Robert
CD Player Quit Working
the only thing i can sagest is that you leave the battery disconnected over night this may reset the cd player and it may Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Recognise that it has cds in it
the only other thing i can think of is that when it says enter single disk only that you do so to a point don't let it go all the way in
this may make the cd player think there is a disk in there
hope this helps
ricko
1helpful
Our radio, cd etc won't work, say code.
The code should be a 5 digit numeric code with no valuer higher than 6. With the radio powered up, enter the code using the selector radio selector buttons labled 1 through 6.
33helpful
6answers
Locked renault clio 2001 cd/radio player!
to enter your code when the cd player displays error leave cd player switched on and after 20 mins or so i will display 0000 then you will be able to enter your code this happens when some 1 has entered the wrong code
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
