Printer error: Ink Tank Error.Replace cartidge which light is off.However, this action doesn't help.Black cartridge light is off.(Thin one)Replacing it doesn't solve the problem.
You either have bought a bad cartridge, or are using a generic or
refilled cartridge, or have damaged the contacts in the carriage
assembly.
Replace the same cartridge again only make sure you use a new Canon
cartridge. If this does not help, either the contacts in the carriage
assembly are bad or the main board has bit the dust.
Repairing the contacts would require you to remove the upper case so
you can access the contacts, remove the ink cartridge and streighten
out the contacts before reinstallig the cartridge.
The contacts are located at the front of the carriage assembly under the ink cartridge.
I have a problem with the paper feeder.The printer worked a minute ago when I printed a thick sheet,...
(More)
I have a problem with the paper feeder.The printer worked a minute ago when I printed a thick sheet, but now won't work at all with ordinary stock.Help
The middle light keeps flashing and does not stop -(No paper jam) - light blink 3 times the stop...
(More)
The middle light keeps flashing and does not stop -(No paper jam) - light blink 3 times the stop then flash again 3 times and so on
The printer is not very old...I am having trouble with the paper feed. ..paper crumples a bit in rt...
(More)
The printer is not very old...I am having trouble with the paper feed. ..paper crumples a bit in rt hand corner and jams.
