Question about Nyko AirFlo XL PS2 743840805304
0 characters
1 Points
My computer mouse and keyboard not functioning well. I replace the keyboard but only last a month.
Hi jhunix,
I'm going to need even more information; The devices that use PS2 connections, which device is it, and how many of those devices do you have?
One thing that might be a problem, if the issue you see is intermittent, I would check the PS2 connector and see if the pins are bent or broken. PS2 connector pins sometimes will bend or break and this can cause some connection issues if not completely stop the keyboard/mouse from working... Also given the age of your PC the PS2 port may just be bad, but this is not a fatal injury to a computer.
Replacing the Keyboard and Mouse with a standard USB keyboard and mouse, should resolve all of your issues.
PS2 is an older technology that keyboards and mice used to run on; Now however USB connections are used.
Further more, if this an HP Desktop with 2 USB ports on the front, and 4 USB ports on the back, you will want to avoid using the 2 USB ports on the front, especially on older HP and Dell Desktops, the reason is the power supplies often do not have enough power to run multiple USB devices on the front USB ports.
The back ports should be fine regardless of the number of devices.
Hope this helps.
Dec 10, 2013 | Keyboards & Mice
Not detecting keyboard with computer
hi ''' if your keyboard is brand new and you just bought it on a store so it is guaranteed good, then you tell me when you connect it to your PC it does not work '''' try to do it again, shot down properly your PC and then connect key board , after boot wait for it to be detected
Jul 12, 2011 | HP D8597A Keyboard
Just bought a hp retractable mouse its supposed to be a plug n play but its not connecting
Are the mouse USB or PS2?
PS2 are the round connectors, and USB are the thin, long connectors.
If it is USB, it should work in a couple of seconds after inserting it.
If it is PS2, you first need to restart your computer with the mouse connected.
If it is still not working, you should check it on another computer.
You should also check the minimum system requirements. (Often written on the box, or enclosed manual)
Mar 05, 2011 | HP Keyboards & Mice
I have a new Dell computer, which has no PS2 port.
No, unfortunatly there is none unless you specificaly ask Dell for a usb driver.
It's a common myth that users think USB has built in drivers in it's hardware. The only resolution to this issue is to ask the manufacturer for a new driver for this specific item to run under usb.
Mar 05, 2010 | Fellowes Touchpad STD PC (platinum)...
Laser doesnt work
Check the mouse cord and make sure that it is properly connected to the PS2 port of you computer. Turn off your computer, wait for a few seconds and then power it on. If it failed to function properly, contact the store where you bought it about the problem. The device is cover by its' warranty and they may replace it if found defected.
Hope this could help you..:-) Thanks..
Dec 27, 2009 | Genius Mouse, OEM Net Scroll PS2...
My desktop doesn't recognize my keyboard
Try a different keyboard on your computer.
If that works, try your keyboard on a different computer.
If it fails, then replace the keyboard.
Sep 10, 2009 | Gateway 2520915 Keyboard
How do i connect my PS2 with my PC
on the back of your computer box, you will (probably) find 2 ports that look like this. the PS2 mouse will be plugged into the green colored port. NOTE: PS2 mice (and keyboards) will only fit into the port ONE DIRECTION, so don't force it! make sure to line it up
once plugged in, you will need to reboot your computer, as PS2 can only be recognized while the computer is starting up.
one final note: some of the newest computers DO NOT have PS2 ports. if this is true of your computer, you will need to get a new mouse, or an adapter, like the one shown below:b6b70e7.jpg
Aug 27, 2009 | KEIO PS2 Optical Scroll Mouse
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Aug 24, 2009 | Dell SK8110 Keyboard
No mice work on my computer!I installed a wireless mouse, and now no mice work, the wireless, and normal keyboard does. How do I fix the mouse socket?
if it is PS2 then you need to reboot your computer in order for the computer to detect the PS2 device ( the PS2 device needs to be plugged in before rebooting )
If USB then try a different USB port and also check bios settings to ensure all usb keyboard and usb mice settings are all enabled.
You could go into device manager and delete usb hub etc and let windows re detect and re install otherwise go to
His site has lots of other useful info
May 10, 2009 | Socket Communications Standard Keyboard...
The ps2 is not working that whell
The PS2 mouse cable goes into the green port on the back of the computer. The keyboard goes into the purple port on the back of the computer. Let me know how it turns out..
Jan 04, 2009 | KEIO PS2 Optical Scroll Mouse
Nyko AirFlo XL PS2 743840805304 Logo
76 people viewed this question
Top Nyko Keyboards & Mice Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Nyko Keyboard and Mice Expert? Answer questions, earn points and help others
