Question about Fisher and Paykel IWL12 Top Load Washer
Washing machine has packed a sad
When I was trying to use the washing mchine today, it wouldnt start its cycle. When I first got it, it worked fine. Then it had to go into storage for 3 months. When i plugged it back in it wouldnt work full stop, no lights, no beeps, no nothing. I replaced the top bit with the lights and the computer part of it and it worked fine, except sometimes it would work with the lid open through the whole cycle. Now it wont work at all. It turns on and the lights come on and it beeps and everything but when I press start nothing happens - even if it is advanced forward to the spin or wash part of the cycle it just doesnt move. I suspect perhaps there is a sensor connected to the lid so it wont go when the lid is open? But i have absolutly no idea what to do. Any ideas?? It is a Fisher & Paykel Smart Drive 053. Well, that's what it says on the top of it.
  • 2 more comments
  • Rowena Campbell Oct 06, 2007
    It's meant to say i suspect there is a fault with the sensor, and maybe it thinks the lid is open and that why it wont work. Sorry!!
  • kbtva Nov 14, 2007
    My machine will run the 1st 2 of the wash cycles. It will get hung up and beep after 2 and before the 3rd wash cycle. I turn off machine, turn back on and hit the start/pause and it completes the whole cycle. Any suggestions?
  • updacreek Nov 27, 2007
    mine is the same, it lights up as if its all good, but when you go to was nothing happens, with or without the lid closed.
  • Anonymous Mar 19, 2014
    when pwered up console lights up then started lid doesnt lock and wont engage wash cycle
    Scholar:
  • 146 Answers
The problem is definitely in the lid switch. Your machine has a reed switch which is located under the hob on the right side of the tub. There is a magnet built into the lid which activates the reed switch when the lid is closed. You will need to replace the reed switch and harness.
Posted on Nov 04, 2007
SOURCE:
Aa class beko 1400 rpm in black...my washer has been fine until today...it did a wash and spun fine...then wouldnt unlock it just kept making a noise (like it was just about to start a cycle) for bout 4...
Try pressing start pause and cancel at the same time. This is the way to overcome a Beko door lock power problem. A bad sound suggests the belt has broken, and that can only be replaced by a technician
Mar 17, 2014 | Washing Machines
My zanussi washing machine wont start a cycle. at first i thought it was the pump because it wouldnt spin cycle, so i put a new pump in and the spin cycle worked. i tried putting an a half load then and it...
Hi tdld6365,
Drain pump may be clogged. Even though you replaced the pump, the filter may still be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Washing Machines
BEKO WBF 6004 XC : causing the circuit breaker down
I think you will find the fuse in the plug has blow and secondly there is probably a short circuit in the heater element as before the wash cycle starts it needs to heat the water and that's when the power fails eric
Dec 25, 2017 | Washing Machines
I have an electrolux EWX14440W Washing machine,
could be your door interlock is faulty
Mar 01, 2010 | Washing Machines
Water wont drain and it wont go into the spin
if it is'nt making anny sound at all in spin its probly the lid switch
Dec 08, 2009 | Magic Chef Washing Machines
Washing mchine stops during cycle and starts beeping
See if you are overfilling you machine or the load is out of balance. Even try running the machine empty
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Frigidaire washer won't agitate
Probably a stripped gear in the transmission.
Jan 28, 2007 | Frigidaire FWS833A Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
439 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
