Question about Fantom Drives 300 GB Hard Drive
Home PC I had thids hard drive for backup at work. We added a server so I brought it home to use as a personal info back up. I wanted to format and erase everything so I could put my data on it. I cannot get my PC to recognize the drive. I do not have the original CD driver or manual it came with. Can I download the drivers to make it work?
    Novelist:
    Champion:
  • 382 Answers
You will have to reformat the drive. What operating system is your home computer running?
Posted on Oct 29, 2007
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
Tip
How to choose a backup device
Hello all,
I work in data recovery and I'm always being asked what kind of backup device my customers should use. The fact is, there are a lot of choices and a lot of different situations with different answers.
Whatever device you choose for backup, remember the most important part of backing up is to always have more than one copy. Your backup device does you little good if it holds the only copy of your files.
USB Flash drives:
Pro's Cons
Most Inexpensive Easy to damage
Easiest to Transport Easy to Lose
High Compatibility Difficult to recover
Fast copy speeds
External Hard Drives:
Pro's Cons
Inexpensive Some are bulky
Higher Capacity Greater damage if dropped
Easy to transport Can be expensive to recover
High Compatibility Some require external power
Faster Copy Speeds
Easier to recover
More rugged
Secondary Hard drive(internal)
Pro's Cons
Inexpensive Not optional on most laptops
Higher Capacity Not optional on all Desktops
Fully compatible Can fail simultaneously
Fastest Copy Speeds Does not protect data if PC Stolen
Easy to Recover Requires some knowledge to install
More Rugged
Less risk of damage
NAS Box or Small Server
Pro's Cons
Higher Capacity Higher Cost
Redundancy is Optional Requires more knowledge to setup
Accessible to all PC's
on your network at once
Fast Copy Speeds
Low risk of damage
Compatible with most PC
RAID5 NAS or Server
Pro's Cons
Highest Capacity Highest Cost
Highest Redundancy Requires most knowledge to Setup
Fastest Copy Times Requires specialized equipment or software
Accessible to all PC's Most expensive to recover if failed
Ability to survive single
drive failures without
data loss.
Now, armed with that short list of options, let's help you decide which option best suits you. If you move around a lot, you go to school, work out of the office or travel for work a USB flash drive is often the simplest form of backup and allows you to move data between home, office or school without lugging a large drive around. we recommend these as a part of most peoples backup solution. Next you will want a more stable form of backup(harder to damage).
For your tougher backup device you will have to decided what kind of budget you have, how much data will need to be backed up and how often. If you have a great deal of data from several computers in your home or office you will likely want to use a NAS box or setup extra drive(s) in one of your existing desktops to use as a server. If you only have one or two computers or the budget just won't cover a RAID or NAS solutions you can simply purchase an external USB or eSATA hard drive, usually less than $100. This can be moved between computers and used for backing up.
Now remember to Sync your data. This means anything you update or create while away that is saved on your USB flash needs to be copied into your computer and your computer needs to be backed up onto the external drive or server.
For more information on backing up, verifying backups and different types of backup devices, visit my blog at http://www.aitsavemyfiles.com/armor-itrecoveryblog.php or search through the other tips available here on FixYa.
on Mar 19, 2010 | Computers & Internet
Hi, I bought a Seagate GoFlex a couple of days ago and successfully backed up my Mac at home. However, when I went to use the GoFlex on my PC at university, the PC was not reading the goflex. Thanks.
Did you reformat the FreeAgent drive when you backed up the Mac? If you use Time Machine or other backup software for the Mac, you had to reformat the drive. If you want the PC to read the disc, it must be formatted in a FAT32 or NTFS file system. The Mac OS formats discs in the HFS+ (extended hard drive format) system.
Unfortunately, if you reformat the disc to a Windows compatible format, you will lose your current backup. The drive will be as a large media transfer disc but not for the backup images. This site, http://www.cs.ubc.ca/~pcarbo/macnexstar.html , has information on splitting the hard drive into two partitions, one HFS+ and one FAT32. Then you could have your backup on one part of the GoFlex and still transfer files from the Mac to the PC and vice versa.
I hope this helps.
May 18, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My Iomega Home Media Network Hard Drive ("HMNHD") used to work perfectly, until I reset my Dell Inspiron 1545 and installed Windows 7 to upgrade it from Vista. I backed up all my files, program data,...
First and the foremost thing is that when u backup any info to an external hard drive try only back up the data that u have saved. Coz application cannot be saved if done they cannot be retrived. Now if those files are asking for permissions then right click on the file - properties - then on the securities - click on add - then Under Enter the object names to seclect type in Everyone then click on Check Name now Everyone will come in Underlined - click on OK - U will come back to properties tab then on top click Everyone - And under Permissions for everyone Under Full Control Check ALLOW - Then OK
this should fix the issue.
If this does not helps, since u have transfered all the data back to the PC why not format the External Hard Drive. Connect the Drive right click on it the see it teh format option is there or not if present then foprmat it.
Aug 01, 2010 | Iomega 1000 GB Network Hard Drive
My Book Home Edition 500 GB hardrive has been shaky lately and now everytime i plug it in it says K: Drive not formatted do you want to format now? It doesnt even pop as My book just the K: drive and when...
This is a sign of a failing drive. Its probably, bad sectors; or a pcb that is about to fail. I would advise you to backup this up promptly. http://techrxgb.com for more information on data recovery.
Jul 23, 2010 | Western Digital My Book Home Edition 500...
Tring to back up pc to elements 1 tb external hd
Fat32 simply means that your hard drive can only read files up to 4GB, format your external harddrive using file system NTFS then try to back up all your files again. Hope it helps you...
Jun 22, 2009 | Western Digital My Book Home Edition 500...
Formatting a tomtom go 710
Hi, I probably cant answer all of your questions but I might help with some of them. You should be able to access your TomTom 710 without removing TomTom home software from your PC. It should be accesses as a drive through the USB connection in "my computer" on your PC. When a USB device is connected to your PC it appears as an external drive. Therefore you should be able to delete , load onto , or format the TomTom hard drive ( or with some other models the SD card ) as you would a normal drive . ( an example of this is where you might have a camer with SD memory card and relevant manufacturers software on your PC . you might connect your camera to the PC via USB and the camera software on your PC automaticly detects the camera for it to eb accesssed . However , the camera and it's SD card can also be accessed seperatly by going to "MY Compter" and it should also be visible there as an external UDB device / external drive ) . Now .. to another another question . If you do un-install TomTom home , I dont think it will also delete any backup of your TomTom , it will only delete TomTom Home software . ( the word "think" is mentioned because I have never tried this ). Besides that , you can choose in tomtom home , where you want any backups to reside , so you could save backups via TomTom home to a CD for istance. If you did that , then you would have the backup on a CD rather than your harddrive which means you could safely un-install TomTom home knowing that if it also removed any saved backup you would still have the CD with a backup on it. So , to summerise.... If it were me , I would make a backup of the TomTom by simply copying all the files on it by opening the TomTom up as a folder in "MY Computer" , simply drag any files and folders from the TomTom into a folder I have prepaired ( call it for instance "my tomtom backup" ) on my PC . Then I would format the TomTom drive then reinstall the backup and see what happens. If the TomTom still doesnt work properly , I would Format the tomtom again then use TomTom home to obtain all relivant files , then copy only the maps and .MAC files ( these are the authorisation files for the maps ) from my Backup to the TomTom manually ( not from tomtom home ). I would guess that would result in a working TomTom again ... Good luck.
Nov 15, 2008 | Tomtom GO 700 GPS Receiver
USB 2.0 Host Controller on Windows 2000 Server (Emachine 5260)
raycrean, Windows 2000 service pack includes drivers for USB 2.0.
http://support.microsoft.com/kb/819332
How do you know its not operating like 2.0?
Jan 19, 2008 | E-Machines eMachines Desktop PC
Adding an external hard drive to a home wireless network
Try setting configuring the privledges setting. Make sure there the network setting is correct, and make sure all user accounts have admin access to network
Oct 06, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Open Questions:
Fantom Drives 300 GB Hard Drive Logo
62 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
