Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Screen size changes
The screen size changes on it's on, from Cinerama to 16:9 format and back to cinerama about every 2 or 3 minutes.
    Genius:
  • 1,153 Answers
RCA hads a problem with it's sets switching back and forth on their own. This is covered under warranty. Some say first turn off the autoformat feature in Customer Menu, if this doesn't work, a board need to be replaced. I would contact Manufacturer and ask is under warranty. RCA/GE same !
Posted on Oct 06, 2007
SOURCE:
How do I make it go full screen
There is going to be a setting in your television menu under display or video. You will have multiple choices and the most effective is automatically select but the second choice would be Cinerama.
Jan 26, 2016 | Televison & Video
Peoples heads are cut off on reg tv not in hd
Since your tv is cutting the heads off durring regular or analog signal but not high deffinition sounds to me like you have to set the aspect ratio different or such as going to your picture format from the main screen. Play with the settings from zoom, full screen, no overscan, cinerama and see if this helps.
Feb 04, 2011 | RCA P52926 52" Rear Projection Television
There are borders on left and right of screen
1 solution that worked on my TV was to hit the format button on my controller and it gives me the option to do full,normal, cinerama, or zoom. These options stretch shrink or blow up the looks of the screen of what you are watching. I usually use full, I may get a few programs that are only half screen whether letterbox or where there is black bars on left and right but not many.. It may be the difference too between digital signal and analog signal.. If you do not have a format button go to your menu page and picture setup, see if you have any of the options of what I mentioned the full, normal, cinerama, and zoom.. Hope this helps you out.
Feb 04, 2011 | Samsung PS42P2S 42 in. Plasma Television
Screen size changes on its own
Use the format button to switch betwen auto, widescreen (16:9), letterbox (4:3), and other options. not all formats are available on all channels.
Fame !
Jun 23, 2009 | Televison & Video
Hello I am having trouble with my picture on my TV. I can't see the top of people's head. Can you help.
go left and right (arrow buttons) on your tv remote to go from 4:3 format, widescreen, 14:9, etc. If you have non-hdtv (full screen), its best to leave it on cinerama or 4:3/
Dec 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Changes modes
Your set could have several reasons as to why it is doing this ,poor solder connections bad ribbon or ribbon connector or SSB board ,i would start with soldering deflection board alot of these sets have poor connection on Flyback Transfomer.
Sep 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV (HD52W59) and Playstation (PS3) Screen Size Issue...
First of all the adapters always give headaches with these TV's for some reason. Try changing to 16:9 instead of Cinerama. I do this by using the direction buttons on the remote left and right change this. Hope this info helps.
Jun 16, 2008 | RCA HD52W59 HDTV Projection Television
Picture format changing
i think that that tv is equipped with an "autotformat" feature there should a setting in the menu to change that option. check owners manual.
Jan 28, 2008 | RCA D44LPW134 44" HDTV
Picture Fades
Here is one possible solution:
1. Go back there and get the remote for the RCA.
2. Towards the bottom right you'll see a "FORMAT" button. Press it and look at the screen each time.
3. This changes the screen format between Cinerama, 16:9, 4:3, and all the Zoom formats.
4. ONE of those should be what you're looking for...
Is there a way to reset this TV back to factory defaults through the menu?Try that. Otherwise it is a more serious problem. Call RCA to see if they can help.
Nov 20, 2007 | RCA HD52W59 HDTV Projection Television
My tv is zoomed in and I can't get it back the way it was to begin with. Is there a reset or something?
On your remote control in the center, the left and right arrow buttons will cycle thru the available screen formats: 4:3,zoom1,zoom2,cinerama,16:9
Oct 10, 2007 | RCA HD52W56 52" Rear Projection HDTV
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
