Question about Sony Cyber-Shot DSC-P73 Digital Camera
Problems with Sony Cyber- Shot DSC-P73/P93 digital camera
After using the camera, when I tried to turn it off, the lense would not retract. I assumed it was the batteries. I was out of town, so put it in my suitcase and forgot about it. After I got home, I realized the lense was still out. I put in new batteries. The lense still would not retract. The power would come on, but the screen is black and says "access". After a few seconds, it begins to beep and says "Turn the power off and on again" An icon also shows up on the screen that shows the battery is getting weak. When I turn it back on again, it just repeats the same steps. Sometimes I am able to go to the arrow that will review the pictures already on the memory stick. It will never allow me to take any pictures. There is also a yellow flashing light right above the screen. Thanks for any help.
  • qwasi Nov 22, 2007
That's what mine was doing after I dropped it with the lens open. I ended up having to have a new lens installed by Sony for $200. I love this camera so to me it was worth it.
Posted on Dec 14, 2007
Had similar problems with a DSC-P93 and found av clue to a solution on the internet: Change to new batteries, the original Sony Ni-Mh 2100 mAh seems to have gone really bad!
//Mats A
Posted on Oct 28, 2007
SOURCE:
Sony Cyber-Shot DSC-P93 Digital Camera - doesnt flash anymore....why?
the flashes burn out after a while or even when bumped like a globe the filament will snap they can be replaced take it into a good camera repair shop for a quote
Jul 04, 2010 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony Cyber-shot Will not power up
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
I need to find the manual for the sony cybershot digatal camera 3.2 mega pixels
manual for Sony DSC-P73 here it is
http://www.docs.sony.com/release/DSCP73.pdf
pls rate me FIXYA for help
Apr 11, 2009 | Sony Cyber-Shot DSC-P93 Digital Camera
Camera
reinstall the sony drivers
Aug 25, 2008 | Sony Cybershot S650 Digital Camera
all you have to do is to throw away your p73 or break it down using hammer. thats all
Jul 24, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Lost my user manual p93 vx cyber shot,
I didn't get one for my p73. Google owner's manual for
Sony p93, and you'll be able to download the entire thing
for free, (on Adobe Reader).
Macro is the little flower looking emblem. You should us a tripod, too and your self-timer. Ed
Feb 06, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Pink display and shutdown
Defective CCD May be subject to a recall and replacement camera - check out Sony Customer support
Sep 26, 2006 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
266 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
