Question about Toshiba TP71G90 71" Rear Projection Television
Toshiba television convergence problem.
I have a toshiba TP71G90, I have a convergence problem. I allready changed the two stk's with original replacements and I still have the problem, It is a little better than what it was before but I can't adjust the convergence in the service mode. It does let me in the service mode but when I try to adjust the convergence by going to built in cross-hatch pattern but it will not show it, also if I try to go to the main menu to select the convergence mode there is no cross displayed. Can someone please help any ideas. I also changed the resistors in front of the stk's.
  • angeldjr Oct 06, 2007
    Also my audio went out at the same time.
  • angeldjr Oct 10, 2007
    I checked the resistors and cap's and they are good, and also the audio went out so can it be something else.
  • 4,889 Answers
Yea, you have to have the two convergence Amp IC's replaced.
This is an in the home repair my friend. Can you solder on printed circuit boards?If yes then i can help you sort it out or if you want to play safe it would cost you somewhere b/w 300-600 bucks...Let me know what you wanna do
Posted on Oct 14, 2007
  • eagle338
    eagle338 Oct 14, 2007
    Sorry i did not see your coments...Your Problem is going to be on the convergence board, there is going to
    be a bad fuse,generaly it is going to cost 100-150 to fix
  • 790 Answers
Ok if you already replace the convergence amp, you can check all small parts like resistors or capacitors maybe you have change value parts at the convergence section!
Posted on Oct 07, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 10, 2007
    ok angel check all regulators! power supply! check the 5v 9v 12v and 14v. 7805, 7809, 7812, 7814,. you make sure that all voltage are in exactly in given voltage!!! if they have high voltage that is bad! because the said small voltages is for the system IC jungle IC chroma IC. very sensitive...
I am having convergence problems and need to know if there is really a difference with Sanyo and Sanken STK IC convergence chips?
Just the name, Sanyo quit making the STK series several years ago Sanken, Toshiba and Mitsubishi all have good versions of the STK series.
Aug 25, 2010 | Zenith R50W46 50" Rear Projection...
The lower left corner of the picture has a red out of line convergence. It will not adjust. what can I do?
The tv have convergence problems is dead.The tv convergence board require 2 STK convergence ICS and some or all it resistors changing.To solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 14, 2010 | Toshiba TZ50V51 50" Rear Projection...
Color shadows
Tv have convergence problems.Ur tv have a "Hyper board" the tv Hyper board convergence are dead on it.The 2 STK convergence ICS and some or all it resistors are dead.Must changes these parts to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 25, 2010 | Toshiba 50H82 50" Rear Projection...
Toshiba TP48C90 Convergence (replaced ICs, worked for 2 days)
Well, my thought is that there are a ton of knock off generic convergence IC's out there that usually hold up as long as yours did. Professionals like me will only use Sanyo original STK's. The counterfeit STK's out there are everywhere. Do some research on the web to locate Sanyo originals, they are out there.
Jun 11, 2009 | Toshiba Televison & Video
WHERE CAN I FIND AN ORIGINAL REMOTE FOR MY TP55F80?
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Mar 02, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
STK IC CHIP 392-110
I made the same repair in a Toshiba 42h81 I replaced the STK 392-110 and after a lot of searching found the cheaper ones last 6 month or so be sure to use Sanyo IC's and replace the resistors with them when the IC's let go they take the resistors out I posted my repair On my page if it will help you dennisgm052.weebly.com
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Toshiba tv convergence problem
did you change the resisters the same time as the ic? some have reported that they got generic IC (cheaper) and have failed.
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 06, 2007 | Toshiba TP71G90 71" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
