Question about Smart Modular SV3170A
Monitor it has power, lights are blinking but no display on screen
  • tajuddin029 May 11, 2010
    my monitor is ibm when i power on my pe light is blinking but screen is blank please send me solution how to solve it
    thanking you
    taj india
Sorry, the best solution is to throw it in the trash... I had the same problem with mine and the store said its broken...
Posted on Oct 22, 2007
SOURCE:
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
My dell e173fp monitor has quit working. The power light continually blinks when power is applied, even without having to turn it on. An identical substitute monitor works fine on the computer system. ...
Is the power blinking amber? This is a DPMS power-save mode. With the computer disconnected and the monitor on, do you see the colored self-test block floating around? With the monitor on, computer connected, and you still have no image displayed, take a bright flashlight and examine the screen closely. If you can see a very dim display in the screen, the fluorescent tubes which light up the *background* and provide the vivid picture(sort of like a how an x-ray picture viewer works) are defective. The power light blinking may be the power supply sensing the non-functioning tubes or it could just be bad. If your display is under warranty, replace it. If not, trying to have the monitor repaired for this type of problem is almost as costly as a new one--and there won't be an active warranty on anything else that might fail. Hope I helped you.---Rick
Sep 10, 2009 | Dell E173FP 17" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
Smart Modular SV3170A Logo
Top Smart Modular Computers & Internet Experts
Pamela Bates
Pamela Bates
dboyz
 Mike M
Mike M
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
