Up air pressure passed 30 no matter how long I let it run. I have checked for air leaks and threaded all connections with teflon tape still will not build up air pressure
Here are some simple tests that will help solve your problem. Check for leaks with soapy water on all the joints and the drain valve. With compressor running and it has reached all the pressure it can muster, remove the air filter and place your finger over the intake port, you should feel good suction and the compressor should speed-up if pump is working and pressure is leaking out. If you feel good suction then pressure could be leaking past cylinder/ring if it is oilless. Check upper part of cylinder for scratches or torn vinyl ring. If you do not feel suction, but rather air blowing out of intake then you may have bad reed vales or torn gasket in head. Another simple test is to run compressor for a few minutes and disconnect power then listen for air leaks at the pressure switch unloader valve. If leaking replace the in-tank check valve (brass valve). Follow the discharge airline to the tank, there you will find the checkvalve. Good Luck and email if you have questions.
