Question about Acer TravelMate 270XV Notebook
Screen resolution at the moment the resolution is 800x600 pixels. i cant change to higer resolution. i have install the video controller but at the end of the installation it suddenly restart the laptop. when i check in device manager it say that the driver of this device are not installed (code 28). i tried many time but it stil the same. what i have to do now. please.....
    Sergeant:
  • 274 Answers
Uninstall it from the device manager and reboot. If you have WinXP it will find new hardware and reinstall it. If you have the new drivers saved on you computer, when the installation program asks for it, direct it to the saved location. Should solve your problem.
Posted on Oct 06, 2007
  • Jerry Hess Oct 06, 2007
    Here's the link to the latest driver:
    http://www.acerpanam.com/synapse/forms/A...
    After you download it and save it, restart in "safe mode", then go to the file and click on it. It should load completely. If it doesn't then go to Acer and have them solve your problem as you should have in the first place.
How to increase screen resolution from 800x600 to 1366x768
You need to get the correct video drivers for your Graphics card or on-board graphics chip. Just go to the support site of the graphics card or if it's on-board video go to the support site of the motherboard to get the proper drivers. Once the correct drivers are installed, you will be able to increase the resolution.
May 24, 2012 | Intel Desktop Board D815EEA2 Motherboard
Screen Resolutions My resolutions changed to very small, when I clicked on the monitor.
Your operating system?
For Windows XP,
  • Right click in an open area on the desktop.
  • On the window that opens select properties.This opens the Display Properties window.
  • Click on settings.
  • On the screen resolution option,set to around 800x600 pixels.
  • Click O.K to save.
For Windows 7,
  • Click on the start button.
  • Click on the control panel and under Appearance and Personalization,select Adjust screen resolution.
  • On the list next to Resolution,move the slider to the resolution you want.e.g 800x600 pixels.
  • Click on keep to save the changes.
For Windows Vista,
  • Click on start button.
  • Click on the control panel and then on Appearance and Personalization.
  • Click on Personalization and then on Display settings.
  • Under Resolution,select the resolution you want.
  • Click Apply to save the changes.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Computers & Internet
Can I increase the screen resolution on my EV700B monitor higher than 800x600? How?
Open Control Panel - Display - Settings tab - Screen Resolution move the slider to the right to increase the screen resolution.
If you cannot increase the screen resolution, it means the correct video driver was not installed generic VGA driver was installed.
In this case install the video driver for your graphics card and change the screen resolution.
Apr 14, 2011 | Gateway EV 700 17" CRT Monitor
I have the driver but it said that i cannot continuie installing in windows xp home because the resolution of the netbook is 1024x768.it should be 800x600.what should i do to install the driver...
go to your start menu - control panel- display - settings then adjust the pixells to 800x600 then apply
then check if it will continue installing
Mar 18, 2011 | Computers & Internet
How do I change my computer monitor to 1680 x 1050?
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig. below, click on the settings tab at the top right of the box.
The areas worth noting are: google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Jan 13, 2011 | Computers & Internet
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Screen resolution stuck in 32 bit 800 by 600 pixels
yeah like techychick said...do you have the latest drivers for your video card? AND...do you have the correct video drivers for the card? cuz thats always the problem...and if it continues try to find one on windows update or u might have to reinstall windows to see if u selected the rights ones....trust me...this happened to me 3 times....
Feb 04, 2009 | Asrock Motherboard K7S41GX for AMD...
Changing Screem Res to 1024x720
Hi LSmitten,
So your brother has laptop, and you can't change the screen resolution, I will take a guess that most likely the screen resolution right now is 800x600 or 640x480 which most games won't work with. The most likely culprit why you are not able to adjust the video resolution is that he hasn't installed the video driver of the laptop yet. You should install the video card driver for your laptop in other for you to change the resolution of your desktop. I suggest that you download the latest video driver from the computer manufacturer's website.
Also if he is using a older laptop, the LCD screen on a laptop has a set maximum resolution that you can use only. Older model laptops can only go as high as 800x600 upto 1024x768. Most of the new laptop nowadays have a minimum LCD panel of 1280x800 widescreen. Check the PC manual to see the max resolution the LCD can handle.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
Screen Resolution
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
Aug 05, 2008 | Computers & Internet
Acer TravelMate 270XV Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
