Question about Saeco Magic De Luxe Espresso Machine
The Coffee bean holder
Hi guys i bought my saeco magic de luxe machine around 5 months ago and the part of the machine that holds the coffee beans (forgot the name) which then grinds them is not working. A red light showing coffee beans in a cup is displayed at the front of the machine which usually means im nearly out of coffee beans although ive got the thing filled with coffee beans! Please somebody help.
  • Anonymous Mar 18, 2014
    fill coffee bean
  • Anonymous Mar 21, 2014
    sometimes works then prompts me to add beans
Nah its all good thanks i figured out the problem and it was rather embarrassingly easy but thanks anyway
Posted on Oct 13, 2007
    Sergeant:
  • Saeco Expert
  • 223 Answers
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: [email protected]
Posted on Oct 12, 2007
SOURCE:
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
I have a Saeco Magic De Luxe. I am having a problem intermittent
Could be the pump not providing enough pressure to force the water through the coffee. When using beans or preground, can you still hear the pump function?
Jun 30, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic de luxe not grinding beans
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
May 05, 2009 | Saeco Magic De Luxe Espresso Machine
Hello and good morning, I have the Saeco Magic model which has been absolutly fantastic, in the last couple of days my machine has been making coffee that has been very watery? How do I fix and could it...
You don't say whether your using ground coffee or beans if using beans chek that no one has altered the grind adjustment on the bean hopper. If using ground coffee it could be that the grind is too coarse not allowing the machine to extract the coffee.
Dec 20, 2008 | Saeco Magic De Luxe Espresso Machine
Whole beans fall through the Grinder
You have to remove the coffee bean hopper, there are two screws on it. Below it is the grinder and there must be a rubber seal between them. Perhaps it is crooked or broken, and then the coffee beans pass and fall down.
Apr 27, 2017 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
338 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
