Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Correct voltage for lamp connection?
The lamp in my set blew after being used for a couple of thousand hours over max life. I replaced the bulb with a new one and got the same problem as many others, error code 34. The set shuts down after a short time and the lamp light stays a steady red. I've tested the new lamp and think it is bad, but I would like to know the correct voltage to look for on the lamp connection before I put in another lamp. I'd hate to blow another bulb if the problem is not with the lamp itself.
  • kryptonian Nov 16, 2007
    I'm having this same problem. My question is where can I get these replacement parts?
    Genius:
  • 1,153 Answers
(Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 .
Posted on Oct 06, 2007
SOURCE:
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
I turned the lights on the high setting for a couple of hours, and the bulb just blew out. I then touched the top of the hood and it was very hot. Should a bulb blow out for no reason? I am worried that...
Check the documentation and make sure the wattage on the light bulb does not exceed what is recommended. For instance: Mine says no more than 75 watts incandescent light bulb.
Mar 14, 2011 | Broan-NuTone Allure QS130SS Kitchen Hood
No video, sound only. Not moved or anything, just picture stopped.
I am not familiar with your TV, but I might be able to help. Sounds like the lamp blew! These lamps only last about 4 to 5 thousand hours. There should be a lamp access on the back of your TV. unplug your TV and remove the lamp housing and inspect the bulb. Be sure not to touch the lens. If it is blown, replace with a new one!
Jan 06, 2011 | Toshiba 51H83 51" Rear Projection...
I turned on my tv and after about 30seconds is sounded like a light bulb blew and the tv went out. whenif is on now if has a crackling in the back intermitently and when you look in the back grill you can...
The tv projection lamp has not been change in this tv the last 1/1/2 or 2 years and been on an watches 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 05, 2010 | Samsung HCM5525W 55" Rear Projection...
MD5880N replaced bulb and worked for 2 hours now nothing
Place heat shielding around the lamp to prevent overheat; use cooling spray (freon) to cool any chips or, circuit boards near the lamp as you attempt to start the set check the lamp for the correct serial # voltage etc.
Aug 02, 2009 | HP Pavilion MD5020N 50" DLP HDTV
I want to buy a second hand rear projection tv, around in 100 pounds is available in the market locally in london from private sellers i am worried about the lamp life, because its expensive to purchase...
an original lamp (original brand name of the tv) can be "alive" there for some years. if you want to buy a tv an suspect that the one is good or not just turn around that area one or a couple of weeks if still working with a great bright and crispy color is good symptom> (some re-manufacture lamps just work a couple of hours even new)
The lamp's life is a question mark in this technology (optimistic ingeniers (brands) count these hours as 1, 2 ,3, (thousand hours) (actually some manufactures count the time ""it is a simple timer the microprocessor can manage pretty well, but is not the mean of a good o bad lamp""
but i recommend my customers to have a spare lamp (just in case you are watching a beatles show) and blowns, you have it in the garage and (consulting the user manual) you change it a as regular bulb in your house.
But the lamp life "and this is the tip": (only two states)
  1. the picture tends to look dark or dimm (is logical because the high intensity the lamp works tends to create a tiny black surface on the heater and tends to consume more current and the answer is a dark picture as i told you already.
  2. the lamp blown (of course the tv cannot work and the LED "lamp" turns on or keep steady on the front panel with a complete dark screen.
Apr 17, 2009 | Televison & Video
My sony kds50a2000 failed lastnight. Bulb only?
There could be something else that caused the lamp to fail but if it has 6 to 8 thousand hours on it that is the expected life and it is not uncommon for a lamp to fail this way.
Mar 10, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Kf42we610
Hi 425hunt
When did you purchase the lamp and how long has it been since it was replaced ?
A lamp normally comes with a warranty of it's own.
I've had a couple cases like yours before.
May 08, 2008 | Sony XL-2100U Projector Lamp for...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
318 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
