Question about Gateway CX2610 Notebook
Screen is black but cpu turns on ;(
Hello, I have a Gateway cx2610 tablet laptop pc. I bought it used and everything worked out great. One day I left it on and it was under the bed sheets, when I came back the cpu was really really hot and i opened it up and it shut down, after that I turned it back on and the monitor flicked grey then black (blank) but the cpu booted normally. I tried to use another cpu monitor and nothing showed up. Any help here? Did my bulb burn out? Do I need a whole new motherboard? video card? Any idea on how much to fix or who i can send it to to fix? Please help me. Also if by any chance I had some information on the hard drive i wanted to keep, how can I get that out? Thanks!
  • Bwicked Oct 06, 2007
    1) is has shutdown before when it was to hot
    2) when i said opened it up, i meant the cpu was closed and i picked the lid up to see the screen and it immediately shut down ( prob from being to hot)
    3)Yes there was a beeping sound as it normally does at start up and i heard the fan spinning and cpu running. I can't be sure though.
    4) I did NOT press the fn +F keys, didnt know that had to be done i will try that tomorrow most likely
    ----------5)I shined a flashlight and seen nothing on the screen at all, it has been awhile since i've touched the laptop and decided to check it out today. I don't hear a beeping sound anymore it just turns on..
    * i had tried taking the cpu apart to check if anything was disconnected or loose and when i put it back together it didn't do the beeping sound but turns on.
    Brigadier General:
  • 6,966 Answers
Hi Bwicked, Based on your post description, it would seem a whole lot of problems and questions. Let's try one by one: 1. cpu was really really hot - this is expected if the unit was covered (bed sheets), however, most units have a thermal protection so it would auto shutdown if it has reached cutoff temperature; 2. opened it up, shut down - the laptop auto shutdown when you opened it up? 3. turned on, monitor flicked grey, then black (blank), cpu booted normally - any beeping sound? What were the indicators that made you assume that it booted normally? 4. Another cpu monitor, nothing showed up - did you try pressing Fn + F? key to enable/activate external monitor? 5. Did my bulb burn out? - possible. If your CPU booted normally, then there should be some semblance of your desktop on your screen except that it is dark. You can try shining a flashlight and you should be able to see portions of your desktop. If yes then you have just confirmed that you have no backlight which can either be the CCFLamp as you suspected or the inverter that powers it; 6. Do I need a whole new motherboard? maybe no but depends on the diagnosis of the problem; 7. video card? most likely no also as some video card are built into the motherboard; 8. Any idea on how much to fix - depends on what is really wrong. 9. who i can send it to to fix - depends where you are. Perhaps your best bet is to seek the services of a qualified professional who is within your immediate vicinity. Further you need to get a firm estimate since it may no be economically reasonable to have it repaired if your assumptions are proven correct. In the same token, an on-site technical person would be able to perform the necessary steps to diagnose the problem. Hope this be of some help/idea. Pls post back with information to the above questions or should you need additional information. Good luck and kind regards.
Posted on Oct 06, 2007
  • Louie  Role
    Louie Role Oct 07, 2007
    Hi again,
    You need to open it up again. Some connectors might not be plugged in securely/properly. You may also want to check the memories.
I just bought it off of craigslist hoping to fix
with nothing happening it is very possible the hard drive that needs replacing or is missing
Mar 24, 2017 | Gateway CX2610 Notebook
I cant find video controller driver for gateway cx2610 for windows 7
Gateway doesn't seem to have a driver created for windows 7 The only alternative I could suggest is to try and download one from ATI's website, a Vista or windows 7 driver should work
Nov 02, 2009 | Gateway CX2610 Notebook
Cannot find wireless switch for my Gateway cx2610
It probably is a small switch on the front or the sides of the computer. If there is not one, then it is Fn+something like F2.
Jun 12, 2009 | Gateway CX2610 Notebook
Gateway xp tablet pc screen is upside down
Give the CTRL + ALT + *An Arrow Key*, if not try, CTRL + *An Arrow Key*, or ALT + *An Arrow Key*.
Sorry, I just forgot which one xD.
Good Luck,
Apr 06, 2009 | Gateway CX2610 Notebook
My CX2610 Internal Mic Not Working
if you need it that much, dont bother wasting time with internal just buy an external mic they cost the same as a mcdonald burger.
Jan 21, 2009 | Gateway CX2610 Notebook
Can not reinstall on my gateway cx2610 laptop tablet edition
refix your ram and harddisk then detect your hardddisk in bios.
Jan 02, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
Noisy Fan
you need to blow out the magnetic dust that build up in the fan try a can of aresol fan spray for computors.
Nov 28, 2008 | Gateway CX2610 Notebook
Stopped turning on
I had the same problem so I played around with the plug by rotating the plug on the jack, so if you remove it and plug it in with a different position it works for me. But the battery does not charge well anymore...
Jul 30, 2008 | Gateway CX2610 Notebook
Gateway CX2610 Notebook Logo
112 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
