Question about Motorola Mobility A1200
Motorola a1200 screen calibration
My screen has offset to the left and I have ben unabled to reset it or recalibrate it. This has rendered the phone useless! Is there anything that can be done to recalibrate it?
  • 2 more comments
  • TRD-Altezza Dec 24, 2007
    I have the same problem with my screen calibration.. It seems as though the touch sensor area has shifted to the right. So trying to recalibrate the screen does not work because the clicks at the the right edge of the screen falls outside the phone area itself.. So a click on #3 on the keypad would actually click #2 or even worse #1.. I managed to recalibrate but after a few minutes or a call it goes back off for itself!!!!! Phone is almost useless now..
  • Anonymous Jan 05, 2008
    Same problem : Stylus touch points shifted to some other co-ordinates on touch pad.
  • Anonymous Mar 27, 2008
    THE SCREEN TOURCH PAD IS NOT WORKING, I DISCOVERED THAT WHEN THE BATTERY WAS LOS LOW THE OK! BOTTON WAS UP AND I TOUCHED SOME DISTANCE LOWER LEFT THE POSITION OF THE RESPONSE AND IT WORKS. THE WORST OF ALL HAS BEEN THAT I CANN'T EVEN RECEIVE CALLS NOR DO ANYTING WITH MY PHONES COS, I HAVE THE MEMORY FULL. EVERY ACTIVITY WITH THE PHONE RESULTS TO NOTHING.
    I TRIED TO CONNECT IT TO THE NET BUT ALL PROVED ABORTIVE. IT SEEMS THAT I HAVE TO DOWNLOAD SOME SOFTWARE TO ENABLE ME OVERCOME THIS PROBLEM BUT I DON'T KNOW WHICH SOFTWARE I HAVE TO DOWNLOAD ONTO MY SYSTEM FOR NOW.
    MOREOVER I WANT TO RESET THE PHONE TO THE FACTORY SETTINGS IF THAT CAN SOLVE THE PROBLEM.
    WHO CAN HELP ME OUT OF THE NASTY PROBLEM I AM HAVING NOW.
  • dalstonrlb Aug 07, 2008
    IT SAYS TOP THE CENTER OF OF TARGET TO ALIGN SCREEN IT WON`T WORK
My a1200's screen is freezing, and it won't load any icon.
Posted on Aug 23, 2008
Hey , I got the same problem after installing new LCD for my moto , I just tried to carefully tap on the crosshair for several time , and it worked , after 2 or 3 times of repeating the process now my screen is successfully calibrated , Just try hard to tap every pixel on that cross hair
Posted on Feb 09, 2010
If the screen calibration is way off then it seems that you can't even click on the crosshair during screen calibration. However, tapping on the crosshair does seem to adjust the calibration a little in the right direction each time, it's just not obvious that anything happened. So the trick is just to keep trying - gently and repeatedly tap the same spot on the crosshair for several seconds - eventually the screen will calibrate.
Posted on Jul 29, 2008
  • cheston_fran Jul 11, 2011
    mines not
    working
Cannot recalibrate my Nuvi 50
Please see this link on how to recalibrate your touchscreen. The procedure should be the same as a Nuvi 14xx.
http://www.sharc.net/discus/messages/6/77.html?1315261162
Mar 30, 2013 | Garmin StreetPilot C320 GPS Receiver
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
My calibration were offset
Good morning,
I have a problem with my Samsung cell phone, its a GT-S5233A touch screen. The problem that I have is the touch screen seems to have shifted down about 1.5cm so I am unable to access my keypad, phonebook or menu. I have tried taking the battery off but then battled to put in my pin as the numbers on the keypad have also shifted. I aqlso tried the recalibration but that just froze.Please assist.
Thanks
Brian
Aug 28, 2010 | Samsung Star GT-S5233 Cell Phone
Need to the motorola ming a1200e master reset security code
my ming calibration screen wont open due to the fact I cannot access my main menus on top...so how can I get the calibration screen to open to claibrate this phone?
Jul 20, 2010 | Motorola Mobility A1200
IS THERE A WAY TO RESET OR RECALIBRATE THE TOUCH SCREEN. CURRENTLY IF I TOUCH THE LEFT SIDE OF THE SCREEN IT SEES ME TOUCHING THE CENTER OF THE SRCEEN. ALL CONTROLS ON THE LEFT SIDE ARE UNABLE TO BE...
Well you should have a calibration setting in the menu's. However if you can't use the touchscreen there should be another way to re-calibrate it. Here is the Owners Manual. http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212667155AVHP5700DVDOperationManual.pdf
Try the reset deatiled on Page 14, I'm sorry but other than that re-calibration is not detailed in the manual.
Was it working fine before it was de-installed
Apr 01, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Unable to send MMS
I have a Motorola A1200 n it is unlocked. My internet is working but I still can not recieve or send picture mail
Apr 16, 2009 | Motorola Mobility A1200
Touch screen repair
The LCD needs to be replaced to correct this issue
Aug 19, 2008 | Motorola Mobility A1200
Motorola 1200
Have you tried calibration? (All menu>setup>screen calibration)
Do you use screen guard? If it is dirty then touch screen may not work.
Sometimes a simple restart may also solve the problem.
Feb 09, 2008 | Motorola Mobility A1200
Screen problem
my a1200 screen doesnt respond anymore wat a waste
Nov 16, 2007 | Motorola Mobility MING A1200
My ming was dropped several times
It appears you have damaged the touch screen. I would suggest taking it into a repair shop or if you are experienced with electronics replacing the screen yourself.
Oct 29, 2007 | Motorola Mobility MING A1200
Motorola Mobility A1200 Logo
865 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
