Question about Sony SDM-P234/B 23" LCD Monitor
Sony sdm-p234 Historical : No menu ,no picture ,power on/off is ok. Hi ,i need your help ,for this gear . I need the soft part and the interface afferent. In the fact situation the monitor tensions are good but i don't have the menu,osd,and rast.The panel control is not working just the on off button.Every button has the same command (on off light-lock at the attach !!!).Yours faithfully,Petter.
2 Suggested Answers
Ezrahite
  • 2632 Answers
SOURCE: SONY SDM-P234/B LCD flat
Welcome to Fixya. As you describe the issue with your monitor it seems that the LCD is ok. Backlight is ok. However, The control board is bad. The control board is the IC that is at the back of the buttons on your LCD it is not responsive. To be able to fix this issue you need to have it checked for possible repair or replacement. You can check the warranty of the monitor so that the repair will be free of charge.
If you have questions please let me know. Thanks for using Fixya.
Posted on Jul 04, 2011
How do I unlock the security lock on the stand from the desk.
Hi
go on setting and reset all setting. it will come on normal mood.
May 25, 2016 | Sony SDM M81 18.1" LCD Monitor
Screen white and power button blinking
Try another monitor if it works ok then the other monitor needs replaceing if it still does the same then you need replace the graphics card.
Terry
Apr 02, 2014 | Sony SDM-HS75P/S 17" LCD Monitor
ETI information box appears on SONY SDM-HS95 monitor repeatedly
You might try checking you monitor setup, you should be able to shut it off by unckng the proper box
Apr 29, 2010 | Sony SDM-HS95P/B 19" LCD Monitor
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
My SOny SDM-S204 has no green in the computer display however, the monitor menu window is the correct color
Hello amellows, hi, check the video cable for loose connection, tighten the vga plug screw, try to wiggle the vga plug and see if there are changes on the display. As for the monitor menu, this is usually not affected, the colors are built in its onboard memory.
Mar 31, 2010 | Sony SDM-S204 (Black) 20.1" LCD Monitor
My sony sdm-p234 monitor wont turn on everytime i turn the power on after a couple of second turns off?
can u enter the monitor menu for adjusting brightness and such?
if yes, connect it to another computer,
if working now - fine!
then your computers graphic card could be the problem!
if not : it is posisbly broke
Jul 23, 2009 | Computers & Internet
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim....
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
G
iamthehipster@yahoo.com
Feb 25, 2008 | Sony SDM HS93 19" LCD Monitor
Picture cuts out after three seconds
The problem is your cabling. Plug the cable from the back of the Comast box directly into the TV. Do NOT plug it into your AMP. See the link below for details. http://www.audioholics.com/education/frequently-asked-questions/why-wont-my-cable-box-video-work-with-my-receiver Good luck.
Jun 02, 2007 | Arris DCT6200 DTV Receiver
SDM-P234/B Won't turn on
Follow this procedure to troubleshoot the monitor. NOTE: Since each of these steps represents a possible solution to this issue, check the display function after completing each step. 1. Download and install the latest video drivers for the video card. 2. Disconnect the computer and monitor from any surge protector or power strip and plug it directly into a known working wall outlet. NOTE: If the display returns after completing this step, the problem is isolated to the surge protector or power strip. 3. Ensure the monitor cables are connected correctly. 4. Perform a monitor self-test. 5. Adjust the monitor brightness and contrast levels. NOTE: Refer to the monitor manual or user guide for specific instructions on how to adjust the monitor brightness and contrast levels. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site. 6. If possible, connect and use the monitor with a different computer. NOTE: If the monitor functions properly, then the problem is isolated to the computer to which the monitor was originally connected. 7. Ensure that the keyboard and mouse are connected correctly. 8. Troubleshoot the computer display configurations in Safe Mode. 9. Remove any hardware that has been added to the computer. This includes any added memory, internal or external drives, and any type of adapter card (network, sound, video, USB, etc.) . Let me know what happens. Good Luck, Tim
Feb 16, 2007 | Sony SDM-P234/B 23" LCD Monitor
Sony SDM-P234/B 23" LCD Monitor Logo
50 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
