Karcher G 2600 VH Gas Pressure Washer Logo
D
Derek Cal Posted on Nov 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Milky engine oil - Karcher G 2600 VH Gas Pressure Washer
Behind_Blue_Eyes
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,727 Answers
  • Posted on Nov 27, 2013
Behind_Blue_Eyes
Master
Level 3:
Renaissance:
Answers
1727
Questions
0
Helped
455102
Points
3267
Suspect water in oil... just change the oil and see if it returns. it's very rare that a pressure pump can get water into the engine
2answers
I have milky oil and my oil pressure gauge reads about 50
Milky oil indicates coolant is getting into the oil . These engines are know for intake manifold gasket problems .
1helpful
Coolant milky and engine lost power whats the problem
Hi Kate
This is rarely a cheap fix as it is likely your head gasket has blown.
See the link below (Sorry about that ad. Skip after five seconds.)
-Steve
Milky oil How to tell if your oil is milky
Oil is milky colored on my kingcraft pressure
Milky-looking oil is a sign of water mixed-in with the oil. This is often a sign of severe engine damage (cracked block, cracked head) in a water-cooled engine. (i.e., one having internal water jackets such as a car engine). On a pressure washer it is sometimes an indication that the owner used the pressure washer on itself, i.e., so as to clean the pressure washer with the pressure washer - very bad idea. If this is the case, then the pressure washer is most likely ruined. In any case the milky-looking oil is a sign that the oil has become contaminated with water, and probably a lot of water. I would drain the oil completely and replace the oil filter too if it has one, then refill the crankcase with new oil. Then try using it again for 10 or 15 minutes or so, then reinspect the oil. If it's milky-looking again then I'd set it out at the curb on trash day.
Oct 20, 2014 • Garden
G2500vh engine problems
Hi Derek.
It is almost impossible for the engine oil to become "milky" under normal circumstances. If you have changed the oil and have used the wrong type, it may become aerated and appear milky. The only other way for water to be added to the sump is through the oil filler. I doubt this is the case as it is a neglect thing and indicates that someone has run the machine without the oil filler caps. Hopefully this is not the case, but as the engine has a low oil level sensor, it might be the reason why it wont start. It's a safety device.
There is no way that the engine oil can be contaminated by water from the pressure pump.
If you mean that the water pump oil is milky, this means that the seals have failed between the pump and the transmission. Difficult to check in a G2500. If this is the case the machine has probably been used beyond the manufacturer's intent and has overheated.
1helpful
O oil life
check engine oil in crankcase sound like leaking headgasket which will cause engine overheating.if engine oil looks milky have blowed head gasket if engine oil dont look milky.do a oil change and filter change replace thermostat see what happens.
I have a 2010 hummer h3 that has a milky color in the radiator we checked all the fluids the engine oil is fine but the transmission fluid is barely touching the dipstick what could the problem be ...........
Milky colour in the radiator means that the engine has overheated and the head gasket is blown and might need replacement after skimming the cylinder head.The milky colour is oil in the engine mixing with water that cools the engine
What would cause loss of engine power and engie oil is milky
compression test possible headgasket check spk plugs as well oil milky means water in engine or high humidity
Milky oil in vr commodore
milky oil in commodore enigine or any engine is the sign off leaking head gaskets or cracked cylinder heads and the coolant and oil are mixing which is the cause of the milky coloured oil
I have milky oil in my motor
if your car ony doing short runs it builds up condensation and gives your oil milky effect
or there is water getting into it
solution give car a good long run and the water should evaporate when engine well warmed up
other wise check water level make sure not losing water in to engine oil
4helpful
2answers
97 Cavalier engine heats up and blows coolant out plastic reservo
Check your oil and see if it is milky lookinig...that is a sign of a bad haed gasket....here is the location of the thermostat...unless a different engine size...then post what you have and I'll get you the diagram here:
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
