Televison & Video Logo
Posted on Oct 06, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recording How to record on dvd from television.
Anonymous
Level 2:
Novelist:
  • Expert 231 Answers
  • Posted on Oct 07, 2007
Anonymous
Expert
Level 2:
Novelist:
Answers
231
Questions
0
Helped
271950
Points
307
Hi, you must have a TV out/DVI graphics card installed first, then the software that would be supplied with it will give you the program to start the basic recording you want to do. Regards mistyman
2answers
Bush dvr3006 will play audio disks but wont play any dvd ! just says load for ages then turns off or no disk ! help please ?
These are the formats your DVR will or will not play.
  • Blu Ray Playback: No
  • Blu Ray Recording: No
  • Compact Flash Card: No
  • DTS Decoder: No
  • DVB-C: No
  • DVB-S: No
  • DVB-T: No
  • DVD Audio Playback: No
  • DVD Player / Recorder: DVD Recorder
  • DVD+R Playback: Yes
  • DVD+R Recording: Yes
  • DVD+RW Playback: Yes
  • DVD+RW Recording: Yes
  • DVD-R Playback: Yes
  • DVD-R Recording: Yes
  • DVD-RAM Playback: No
  • DVD-RAM Recording: No
  • DVD-RW Playback: Yes
  • DVD-RW Recording: Yes
  • DVI Interface: No
  • DivX Playback: No
  • Double Layer Recording: No
  • Electronic Program Guide (EPG): No
  • Ethernet: No
  • Firewire IEEE-1394 Interface: No
  • HD-DVD Playback: No
  • HD-DVD Recording: No
  • HDMI Interface: No
  • HDTV: No
  • IPTV (Internet Protocol Television): No
  • Integrated VCR: No
  • MP3 Recording: No
  • MPEG4 Recording: No
  • Memory Stick: No
  • Multimedia Card: No
  • Number of Scart Interfaces: 1
  • PCMCIA Interface: No
  • Progressive Scan: No
  • Real Dolby: AC3
  • Secure Digital Card: No
  • Show View: No
  • Smart Media Card: No
  • Super Audio CD Playback: No
  • Super Video CD / Video CD Playback: No
  • Table / Portable: Table
  • USB Interface: No
  • W-LAN Connection: No
  • xD-Picture Card: N
2answers
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Westinghouse television manual for n how to attach external DVD recorder and player
Connect the video out (DVD) to the video in of TV which is the AV socket.
connect video out (TV) to video IN of DVD for recording.
Connecct similarily the Audio out L&R (DVD) to the audio IN of TV , L&R. If this is on the AV1 then choose AV1 for playback.
connect audio out L& R of TV to Audio IN of DVD L&R for recording of programmes.
Do you have to finalize after recording from a camcorder they both are sony camcorder and sony dvd recorder
Yes. Any dvd disc recording has to finalize. This is the same for audio and video cd or dvd recording.
Recording on the Meos 20'' LCD-DVD Combo 2009 model
YOU CANT RECORD FROM A SCART TO USB, THE SCART IS IN ONLY AND ANALOGUE. YOU SHOULD HAVE A USB PORT ON THE TV TO PLUG IN YOUR STICK OR PORTABLE HARD DRIVE
2answers
When i am recording from television and i turn television off the dvd appears to be recording but there is a blank screen when i check it to play
are you using AV jack to connect the recorder with TV for recording porpuse. if it's correct then it's simple, if recorder not gate inpute signal from TV, then it must show blank screen. coz it receiving the vedio signal from TV.
hope you get the answer.
thanks
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
2answers
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
