Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Color went black, Now no picture
This TV was worked on in April 2007 and the Light Engine had to be replaced. Five months later the color went dark and now we do not have a picture at all. Could this be a lamp problem??
  • Tracey Howard Oct 06, 2007
    Please explain color separates blue and red? Thanks
    Genius:
  • 1,694 Answers
Research at www.HitachiServiceUSA.com ..........T.
Posted on Nov 09, 2007
SOURCE:
Samsung LED TV picture went dark, still watchable but backlight is set @ 10, Contrast 95, Brightness 100, Sharpness 67, color 32
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 06, 2016 | Samsung Televison & Video
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
Started with one thin horizontal black line, then 3 shades over screen, now only static picture
Check and replace its back light CCFL lamps. If these are faulty, this kind of fault can occur. When replace it, replace all. None one or two. If you wish to get more details about the back light CCFL lamps and its working, check this link. Pull up older posts there.http://electronicshelponline.blogspot.com/
May 28, 2013 | LG Televison & Video
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Panasonic Rear Projection TV
its either the color wheel or light engine they can both cause this symptom. I would inspect the color wheel see if its brken or at the very least got a good connection as thats alot cheaper than a light engine.
Mar 03, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
