Peavey PV6 Mixer Logo
J
Jeff Tyner Posted on Nov 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
High pitch feedback
I'm getting a weird high pitch feedback when I'm in recording software (GarageBand, Spreaker). Once I close the program the feedback stops. But whenever I want to actually use it the feedback returns. I'm on a Macbook Pro running OS X 10.7.5
Ifixstufff
Level 2:
Champion:
New Friend:
  • Peavey Expert 232 Answers
  • Posted on Sep 20, 2014
Ifixstufff
Peavey Expert
Level 2:
Champion:
New Friend:
Answers
232
Questions
0
Helped
81714
Points
292
You are sending the signal back on itself, hit the usb to main switch to off.
I have a used synth, and want to use it as a controller keyboard for GarageBand and other programs.
https://www.google.co.uk/search?espv=2&q=macintosh+MIDI+interface&spell=1&sa=X&ei=BKrLVOGMHpKBabLCgfgN&ved=0CBwQvwUoAA&biw=1920&bih=971
Dec 09, 2014 • Music
Trying to record a mix through a peavey board. I do not get a high pitch hum until I click rec on my Mac. I am connected via usb to the mixer board. Any suggestions on what I might could try to stop this...
First, check your levels on the console. Is anything turned up high, channels, gain settings on channels? Check and see if the noise exists whith the main outputs muted or turned down. If it goes away it is a fader or gain setting on a channel. If it persists, then you have a co nection issue with the USB . Try a different cable. Make sure the Mac is on the same electrical circuit as the mixer, or if it is on battery, try adding it on the electrical circuit with the mixer. See if location of the mixer to the computer makes a difference as well. They may be too close to each other. Hopefully one of these things will fixya.
Nov 23, 2014 • Music
2answers
I have a peavy classic 100 2x12 1975 has a high pitch squeal coming out of amp when powered on
If this happens only when the guitar is plugged in, most likely there are two possibilities. The first, you have some issues with the electronics in the guitar OR are using an acoustic guitar witch has an extremely sensitive pickup that provides nothing but feedback. If this is happening with the guitar unplugged, there is a mountain of possibilities.
Sep 01, 2014 • Music
A high pitched ringing through the PA associated with strumming
You are proabably getting regeneration. This is nothing more than feedback as these acoustic guitars are good microphones. Make sure the guitar CANNOT "hear" the speakers of the PA system. Crank the high frequency EQ for that channel all the way down. This is common when soundment decide they ALSO need to boost the high frequencies of the PA up when they shouldn't. Regeneration is a feedback that is below that to fully sustain, but will cause a ringing "tail" on notes.
1helpful
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
I plug it in and all it does is make a high
Make sure you either use a fresh, name brand battery or correct AC adapter.
Turn all controls down at first as it is possible this pedal may feedback internally if controls are all up.
3answers
Lexicon alpha interface is recording a faint high pitched sound
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
