Typically, Its a matter of removing the leaking injector, Removing old o-ring(s), lubricating new o-ring(s) and gently re-installing assembly. once done, plz check for leaks to ensure injector sealed once running. Hope this helps.
Replace it.
SOURCE: airbag light on what does that mean
It means that your airbag system is not fully functioning and you need to have the dealer check it out. Whenever the airbag light stays illuminated after starting the vehicle, it means that there might be a problem with the air bag system and a check up is needed ASAP to make sure the system will operate properly in the event of an accident. It could be a faulty sensor, or it could be that a wire or connection is loose, etc., in any case, the dealer will need to check the airbag system to determine what the problem is.
I had a situation where an stereo installer had probed the wires in the airbag system and that caused the system to become non-functional, due to having voltage applied to the airbag wiring where it shouldn't have any voltage. It was an expensive fix, as he'd actually stripped the wires bare and he crossed several. Cost him a bunch to replace the wiring harness on my new vehicle.
SOURCE: Where is a fuel filter located on a 2002 mercury
Here's a step by step, with photos, on how to replace an Explorer fuel filter. The Mountaineer should be exactly the same. The problem you describe can be attributed to the fuel filter. Good luck.
SOURCE: Where is the fuel filter located at on a 2006 Mercury Mountaineer
it should be on the inside of the frame rail
