Question about Jwin JD-VD149 DVD Player
Player Does not play any type of Disc
Jwin JD-VD149 DVD player displays "LOAD" and attempts to read the disc inserted. After about half a minute it displays "NO DISC". Player does not play any type of disc inserted.
  • Keith Brathwaite Jan 19, 2008
    ihave a coby it will not start disc up
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Posted on Nov 10, 2007
SOURCE:
Err Disc
did you try another dvd? if yes, and still having issues, sounds like you got a defect product.
Oct 16, 2009 | Jwin JD-VD149 DVD Player
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
After disc is loaded, it says "unknown disc."
Is it a pirated dvd? If it is, do you know some dvd players won't read pirated dvds? And if it isn't, then your dvd player may be dirty (the lens). For that you would have to buy a cleaning disk. You can get one at Radioshack. Or maybe what type of dvd type is it? Is it dvd-r, dvd-rw, or what? Some dvd players have trouble reading dvd-rw sometimes.
Hope this helps.
May 08, 2009 | Jwin JD-VD140 DVD Player
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Dvd disc is not recognised after loading
i would like the code for this jd-vd141 dvd player
Oct 09, 2008 | Jwin JD-VD141 DVD Player
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
Sep 21, 2007 | Jwin JD-VD149 DVD Player
Dvd player not playing discs
did you check to see if you had the audio video cables on the dvd player plugged in the right place also you might want to get a s-video cable it is much easier that way not toooo much problem to hook it up you plug it in to your tv and the other part of the cable plugs into your dvd player where it says s-video
Aug 08, 2007 | Jwin JD-VD136
Jwin JD-VD149 DVD Player Logo
239 people viewed this question
Top Jwin Televison & Video Experts
Ekse
Jaime Hernandez
Sheldon Dedek
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
