Question about RCA RTD258 System
No video signal
All my sound is working correctly but i cant get a menu or any video on my TV. I have umplugged and replugged many times and it is not the problem. M brother told me he was playing around with the resolution on the menu and he pressed 1080p and it went to no signal. If the resolution is the problem, please provide the steps on restoring the video since i cant see the menu. Thanks.
  • 2 more comments
  • mich_mark Nov 10, 2007
    I think that my RCA RTD258 switched over to a HDMI setting and now i get no video signal on my TV. I can not access the menu as you have to have video signal to read it on the TV. Any advice on how to reset this?
  • Anonymous May 10, 2008
    I switched from 480 to 1080 and unable to get setup menu
  • louise_gille Aug 13, 2008
    my husband was in the menu and now we don't have any picture and we can not go to the menu. All the wires are well plug-in.
  • hacraft Dec 24, 2008
    mine has the same problem with no video output tried pressing and holding subwoofer button still does not work what else could i do?
• The resolutions available for HDMI output depend on the connected TV or projector. For
details, see the user’s manual of your TV or projector.
• When the resolution is changed during playback, it may take a few seconds for a normal
image to appear.
• If you set the HDMI output resolution 720p or 1080i, HDMI output provides better picture
quality.
• If 720P or 1080i is selected, C-VIDEO, S-VIDEO and component video will not ouput video
signal. Press and hold the SUBWOOFER button on the front panel to reset the HDMI
Resolution setting.
Posted on Dec 26, 2007
  • 31 Answers
Dear friends, don't worry ,
really this problem have a solution.
i have a lot of experience with that model and i use this.
turn on the unit
wait to no disk message.
press continuosly the subwoofer button until the video resolution is setup to default mode. 480 dpi and the hdmi mode is setup also to default.
try this and after you tell me.
sorry about my english, this is not my mother tonge.
Posted on Sep 19, 2009
SOURCE:
Panasonic TH-58PZ700U, has sound, no picture on any input. Will show photos from photo card inserted into SD card slot. One person said it may be the A board.
Ur tv still able to see picture photo on ur tv video functions,tv should be still able to work.Tries tv and cable or satalite boxes unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting and those pay boxes to reboot and upgraded it softwares.U have the tv original remote?Yes?Push the tv menu button if ur tv have a video menu than it is a very good new.Tries tv resetting every modes on the tv Menu back to factory setting.Tv should funsctions again.After tries to resetting the tv and rebooting those pay signal boxes,if tv still getting no tv video signal.Than those tv backlight buffer boards for the Plasma screen X or Z are dead could be either X or Z or both.Find the closed it is authorize LCD and Plasma tvs shops for repair.Best because they have the equipments to determine the exact buffer board is or are dead.
Aug 17, 2011 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
It seems to forget its freeview channels and starts to run through every channel, interupting tv service provide by scart connection to talktalk box. First sympton is the sound volume icon appears on...
Tries tv and the box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The box to upgraded it softwares.Tv should be working again.If still have the same problems.Take ur tv backcover aparts and disconnection of the tv side manual control board PCB wire connection plug in that have like Power,Channel - +,Volme - + and Menu so on buttons switches.Turn the tv on and see if tv funtions correctly If yes than the tv manual cotrol buttons PCB board have to be change.If the manual contol board is diconnected from the tv Tuner signal board and have the same problems.Than ur tv have a bigger problems,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control PCB board or the tv Tuner signal boards for the replacement.
Apr 07, 2011 | Samsung B2230HD LCD TV
When surround sound is turned on, speakers on TV will not work. how can we fix it so we can use both on a Vizo TV
Tries tv unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.Used ur tv remote.Go into the tv menu goto Audio Setting.Go down to do a resetting.Now,tv will work as Mono or Surround sound by the tv stations incomming broadcasting tv signal aloud.
Apr 02, 2011 | Vizio Televison & Video
My Naxa NX-546 LCD TV/DVD combo no longer has sound. I've tried every menu option I can think of. Any idea what could be causing this?
Tries unplug,replug tv back about an hour later.The tv should be resetting itself back to factory setting,sound should work now.Still have the same problems.The tv Tuner signal board is shorted and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 28, 2010 | Naxa Electronics NX-546 20 in. LCD TV
I see someone else has had a similar problem(Jun 15,2010), but no solution posted yet. I have a monster surge protector. It worked the first night that we lost power. I reset it and everything was fine....
Unplug the tv and the cable box about an hour,replug both devices back in.The cable box will reboot itself and upgrade it softwares.The tv should have signal again and work.
Jul 16, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
No picture, good sound
It's most likely the video board. The menu is injected at the output of the video stream right before the LCD panel. Having audio indicates the signals are getting from the inputs through the input switcher and audio boards. Unless you have electronics experience, I suggest having an experienced tech look at it.
Apr 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Jan 02, 2007 | Samsung TXJ2754 27" TV
RCA RTD258 System Logo
440 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
