Question about Panasonic PT-51HX41 51" Rear Projection Television
Replacing STK392-110 IC Panasonic PT-51HX41 51 in. Rear Projection Television?
I'm in the process of replacing my two STK392-110 IC . However there are 4 white connectors connecting the two boards together. Whats the best way to disconnect or pop these out without any damage? I've removed all the connectors on one side. I'm in a position to remove the left board but only these 4 connector chips are holding me back. Any thoughts or help would be appreciated.
  • 5 more comments
  • wooza Oct 06, 2007
    Hi to get more information should I put the screw driver on the right side or lift the tab on the picture cicrcled in black? See the circle in the picture
  • wooza Oct 07, 2007
    Hi TVtech.. Chips have been replaced and convergence is FIXED... Thanks
    However when I watch TV now I get a BLACK box in the middle of the screen. This shows up watching TV or my VCR.. however DVD's they play fine.. Any ideas? The black box goes away temporarily when I click on the menu guide or if I turn the volume up or down. When I change channels it clears for 2 secs and then it pops up again... thanks for your help so far!
    TV tech.. never mind.. I shut off the CC and the black box is gone.. Thanks for you help again!
  • wooza Oct 08, 2007
    Oh by the way these were the chips we replaced the old ones with - STK392-110 Original Sanyo IC TV 38v 3a 15Khz max..
    Reading on the board - someone said maybe the 150 series??
    Wooza
  • wooza Oct 09, 2007
    Hi ...no the red power light is off .. doesn't blink.
  • wooza Oct 12, 2007
    TV Tech am I SOL or any thoughts?
  • Anonymous Sep 14, 2008
    Hey Wooza. i had the same black box problem on my 51" rear projection display and your tip on the closed caption solved it for me immediately. Thanks!
    Ken
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Just put something under the connector (like a screwdriver)and lift up....they are very sturdy and I have never had one break for me.
Posted on Oct 06, 2007
  • 1 more comment
  • David Makowski
    David Makowski Oct 06, 2007
    If there is enough to grab hold of you can lift it by the tab....otherwise just gently lift it up by going underneath,you will see it move (on the right)
  • David Makowski
    David Makowski Oct 07, 2007
    You have CC (closed captioning) turned on and it is in text mode...just go to the menu and turn it off.
  • David Makowski
    David Makowski Oct 09, 2007
    When the TV shuts down is the power light blinking 3 times?
TV Tech - well another issue has cropped up today. The TV turns on for about 15 secs and then automatically shuts off. Seems like a power supply issue but not sure.. Your thoughts?
Posted on Oct 08, 2007
SOURCE:
Panasonic TV words are backwards
Digital processing issue---some have a jig or laptop that can be used (Panasonic has this) to reset the micro or eprom and correct this with out replacing a board....varies by model---Might give Panasonic a call and have some words......
Nov 06, 2012 | Panasonic PT-52DL10 52" Rear Projection...
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Replace stk392 on panasonic tv
yes.u can easily replace the stk ic.but you should be perfect in soldering the ic.thats the main thing necessary in replacing the ic. to get the full instructions step by step with diagrams just click this link and follow http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
please do rate the solution . thanks.
Feb 09, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt 53tw53 rear projection
Check the vertial output IC. either for defective solder or defective IC. This model has a feature if the vertical output IC fails for any reason the picture tubes blank out as a safety issue.Thereby giving no picture but audio still functions.
Mar 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Problems with Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
sounds like the blue convergence IC is bad.This is quite common in all Projections units about 3 to 4 years old.
Jan 31, 2008 | Panasonic PT-53TW53 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Convergence issue
so you keep buying new tvs each 4yrs or so..all about money..
Jul 28, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
1,593 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
