Question about Canon PIXMA MP510 All-In-One InkJet Printer
Error 5100 After a year of use, my cannon MP510 printer is printing blurrie. I have tried all the maintanence procedures. And I am now getting error 5100 almost every time I print.
  • Anonymous Jan 23, 2008
    i had a paper jam then a long thin piece of foam came out of the machine dont know where it goes now i get error code 5100 everytime
  • 4,345 Answers
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
SOURCE:
Can I print cd/dvd labels please ? Cannon MP510 I have a pack
Use this simple little free app
http://www.medea.co.uk/buy/expressit-cd-labels-cd-covers-design-software-by-pressit-free-p-2014.html
Jul 26, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Service error 5100
Solution 1:
Solution 2:
Dec 17, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 19, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Oct 08, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
May 30, 2009 | Office Equipment & Supplies
Makes a horrible noise
The printer gears are fail, find a canon service center
May 22, 2009 | Canon PIXMA™ MP510 All-In-One InkJet...
Everytime I try to print Error 5100
Hi, Error E22 5100 is a carriage error. Check that nothing is stopping the cartridges from sliding back or fore acroos the silver bar inside the front of the printer.
Nov 05, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error code
Hi You can Try gave it go
Error Code 5100
Solution 1:
Solution 2:
Sep 12, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Error 5100
  1. check the user manual if you had one for that error code,
  2. and I suspect the ink level of your printer,
  3. and also check if there is any paper jam exist,
  4. disconnect the power source for 2 mins and turn on again.
  5. try to print again.
Apr 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
495 people viewed this question
Clive
Clive
old marine
old marine
Ekse
