Question about HP OfficeJet k60xi InkJet Printer
Hp officejet v40 paper won't guid in the copier stright
Put the paper in the copier and it won't guid in stright, even if i hold the paper sometimes it goes in crooked. don't know what it is doing or how to fix the problem
    Problem Solver:
  • 7 Answers
SOURCE:
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
May 15, 2016 | HP OfficeJet 7310 All-In-One InkJet...
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
Crooked copies
Tighten the fences and guides that hold the paper in place. If the paper is not snug in the tray, it will not pull through straight.
May 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Paper not feeding properly, sometimes it goes through crooked and sometimes it isn't grabbed and put through printer
The little wheels that 'grab' the paper sometimes become too smooth and will simply slip on paper. There is wheel rejuvenator you might find at a local stationary store or you might want to try an alcohol soaked q-tip on the wheels.
Dec 02, 2009 | Canon PIXMA iP90v Printer
Copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
Aug 04, 2009 | Konica Minolta bizhub C250 All-In-One...
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Crooked Paper
Are ou fanning the paper before you put it in and cloing the paper guides tightly against the end and the side of the paper? Also, I would look for a tiny jam that is obstructing the paper.
Aug 21, 2008 | Lexmark X1270 All-In-One InkJet Printer
DI3510f
Try to reload the copy paper in the LCT staight and even and also make sure the sides of the paper guides are flush against the paper in the paper tray...
May 19, 2008 | Minolta Di3510f Bizhub Copier
Epson Stylus CX4600 pulling paper in crooked
Hi, please check if there is a paper jam or any obstruction inside that printer. Check also the platen lever or the left edge guide, make sure that paper is loaded correctly. Try printing again. If issue still present. Your printer needs to be send to service center.
--->>> Tirzo
Oct 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Crooked Copies
dear sir please check the upper heat roller claws set,may be one of them is bended up
Sep 27, 2007 | Panasonic Workio DP-4530 Copier
HP OfficeJet k60xi InkJet Printer Logo
35 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
