Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
I am getting blue lines across my tv and then it loses the picture on occasion.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
If it is white brightlines along with blue back ground please check 1 sypply to blue video output transformer. 2 crt base or connector loose. 3 check components related to blue video ckt & blue video output transistor. 4 blue signal reaching to blue video section 5 verv very rare case if set is old set then there is a possibility of crt. hope this will help.
Posted on Oct 08, 2007
SOURCE:
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV.....Turns
Sounds like a diode may have burnt up or if your really lucky it might just be the fuse.!!! You might want to get a secound opinion .But if you know what to look for , which is any component on the motherboard that appears as if had caught fire sader it out amd replace with exact same component which can be ubtained at radio shack.GOOD LUCK TOO YOU!!!!!!!!!
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Sony FD Trinitron WEGA KV-34HS510 ... does not power up.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.This may help the solution or let no what is wrong!!
  • Jan 16, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Sony Trinitron KV-32FS12
    i think your tv had a lose contact or crack on board
    Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    SONY FD TRINITRON WEGA KV-32FS12
    That generally means that the CRT is weak and is putting out low emmisions. This is confirmed by the fact that the color quality is not that great when you can see a picture IE: not enough red, green or blue. This is very common when these CRT's age.
    Sep 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    FV-27KV300 WEGA 27" Sound Problem
    adjust the sound IF in the tuner or in the IFblock
    May 03, 2008 | Sony FD Trinitron WEGA KV-27FV300 27" TV
    Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
    Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
    Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
    Hello im having problems with my sony wega
    It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
    Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
    Sony Wega model # KV-36FS12 it doesn't work can u help me?
    This is due to humidity in your area. Due to moisture content screen control section getting corrosion. cleanit and adjust the screen control to get the normal picture.
    Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
    119 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
