Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic Model No. PT-47WX42F
My son was playing with the television and now all images appear to be 3-d. there is a double image and all tv prompts are doubled in green and purple / red. please help! i have tried to adjust the contrast, the color i.e. green / red, and have pushed almost every button there is. is there a re-set button to restore the original settings? i would appreciate any feedback. thank you.
  • Anonymous Feb 19, 2008
    I have the same problem mostly the green but some red too. I have messed with the convergence 1 and 2 trying to fix it but doesn't seem to help. The left side of tv seems worse. When I do the convergence 1 the green vertical line does not seem straight. The top of the -lines up with the center of the tv mark but the bottom is off a little. Any advice??
  • 934 Answers
Replace the convergence amps. That unit takes two Sanyo STK392-110 and you could use 150's for greater reliability. Also replace one or more of the 1.2 ohm resistors in the yoke return circuit out front of the amps.
Posted on Mar 02, 2008
SOURCE:
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX42F does not come on light flashes 3 times HELP!
There is a service manual which should cover this model/chassis series:
Elektrotanya for electronics experts
(PDF format - free - no sign-up needed - 100% clean)
Page 11 ('auto diagnosis feature') shows a table of LED flashes and what each one means. I'd start by checking D-board (since that is power and deflection) and going from there.
Dec 21, 2017 | Televison & Video
Circuit problem possibly??
i paid a repairman to fix it and got additional info that i didn't know about HD TV's. only $275
Mar 07, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Please Help... Strange blue reflection across screen (See image)
Convergence ICs are bad and posibably th eresistors that power them. Its an easy fix if you can solder
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Pt-53tw53g March 2004
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
462 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
