Question about Refrigerators
Freezer is cold but not freezing
I have a GE side by side model #GSS25JFMAWW that is about 6 years old. I had this problem about a week ago and defrosted, cleaned the compressor of dust, etc. It starts with water coming from the bottom of the freezer side door. When you open up the door the freezer is cold but things have started to thaw. I am not sure what to try next.
  • Sassyk98 May 12, 2008
    Kenmore bottom freezer, freezer is cold but not freezing and there is no ice in the freezer.
  • 248 Answers
Look for frost on back wall of freezer on bottom half. If present it's not defrosting. Number 1 culprit is a defrost heater gone bad. You will have to remove lower cover in rear of freezer section to expose coils. Unplug unit pror to doing this. The defrost heater is at bottom of these coils. It has wires to both sides of it. You will need to check continuity of heater or remove heater and take to appliance store and have them check it. If it's open replace it. Use a hair dryer to remove frost from coils to restore airflow. If heater is ok, problem could be a bad thermistor or a bad board. Let me know how you make out with heater.
Posted on Oct 06, 2007
  • 290 Answers
Do you have a build up of ice in the bottom of freezer? If so, you probably have a clogged defrost drain.
I have a Ge side by side model #GSS25TSR. It is 4 years old. the problem started 4 weeks ago. Things are freezing on the refrigerator side in the vegetable drawer and on the shelf above the meat drawer. I...
you've already discovered your problem. its not blowing. if the freezer fan motor is not blowing air through unit, the cold air falls to the bottom of both sides, and warm air at top of both sides as well. On that model, the fan itself may be bad, or it may be the main control board behind the unit. Without properly testing and inspection, I cant be certain if its one or the other or quite possibly both, And I was trained directly from GE about this.
www.FixMyFridge.net
Mar 08, 2010 | Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Refrigerator won't cool and freezer has ice build up on back.
its a defrst problem most likely the defrost thermister wr55x10025
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Freezer isn't freezing all of a sudden but frig. side is still cold
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Oct 14, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer will not defrost on its own GSL25JFPE
Most likely, the defrost system has failed. There are three components: a defrost timer, a defrost heater, and a defrost bi-metal.
I would have suggest replace your defrost heater.
Jul 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Food freezing in refrigerator.
I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
PS - i did vacumn the back filter a week ago with no help.
Jan 27, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
383 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
