PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Philips freevents x52 laptop raid dri...
By parkook on Oct 06, 2007
I format the hard drive and tried to install winxp and found that there is a SATA HDD instead of normal ATA HDD. I don't have the floppy drive for the raid driver.
When I am trying to install win xp home I have to press F6 and use a floppy which I don't have could you please send me the driver?
Thanx
Comments:
Oct 17, 2007
I have tried intel 945 chipset but it doesn't like it.
Oct 17, 2007
yes
and made a floppy from it and when used it for F6 prompt, it gave me 3 option of devices to choose from, I have tried all of them didn't helped. still can not find the hard drive.
Oct 21, 2007
I managed to format the HDD and installed windows Vista. Now I need drivers for Ethernet Controller, Mass Storage Controller, Network Controller and Video Controller.
Could you please kindly let me know where can I download them.
Many Thanks
Same Problem
May 15, 2009
-   non trovo i drivers della lan
-   Guest
Best Solution
posted on Oct 06, 2007
Very Helpful)
hughv
Rank: Wiz
Rating: 83%, 315 votes
It's not easy to find info on this machine.
I believe it has an Intel 945 chipset, and you can find the SATA driver here:
http://www.intel.com/support/chipsets/sb...
Comments:
Oct 17, 2007
- I believe that's the correct chipset. Did you download the mobile version?
Oct 18, 2007
- If you've downloaded the correct driver and followed the procedures, you have to start considering if there's some other cause, such as faulty hardware.
I suggest checking with a local shop at this point.
Was this helpful?
Yes
No
Solution #2
posted on Apr 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have a problem that find the SATA driver for Compaq Presario V2000
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
says disc error will not start and no disc are in
Answer
i am having trouble with my driver. it says it is a code 10 in my device manager/ cd/dvd rom with a... (More)
Answer
Hello. I am having an issue with my Compaq Presario C700 (C774TU). After about 30 to 60 minutes of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
