Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
15 HP OHV Kohler engine with no compression
I have a 15 HP OHV Kohler engine that is in a Scotts lawn tractor. When I try to start it, it doesn't fire up, there is alot of blow by coming out the carb. I checked the compression with a tester & there is no sign of any compression. I removed the pushrods so the valves do not open & the blow by still comes out the carb. with both valves closed still no compression.
Any idea what the problem is?
Thanks!
  • planekrazy May 06, 2009
    Intake valve was bent & not seating.
jdthefixer
Level 3:
  • Master 747 Answers
  • Posted on May 03, 2009
jdthefixer
Master
Level 3:
Answers
747
Questions
0
Helped
314501
Points
2412
Have you checked for a bad head gasket?
Check the intake valve springs or the intake valve shafts to be sure they aren't stuck open. Another cause could be excessive carbon build up on the intake valve causing them to not seal.
If you've gone this far, you could try a compression leak down test. If you still have the push rods out, you can use or get an adapter that will allow you to pressurize the cylinder(s) with air by removing the spark plug. Apply 70-80 psi air directly to the cylinder (the cylinder may go to BDC (bottom dead center) but if you don't have any push rods, the valves can't open.
Listen carefully - if you hear air leaking out of the carb, it's a bad intake valve. If you hear air from the exhaust, it's an exhaust valve. If you hear air from the crankcase breather, it's piston rings.
2answers
Starter kicks in but wont turn engine acts like too much compression,battery is fully charged
Very can be if it is an OHV engine that either the valves are needing adjusting or the decompressor has failed.
Most 4 cycle small mower engines have decompressors to help with the starting, These are only active at start-up and does not effect normal engine compression when running.
Timeing for LT1050 I have way too much compression!!!!
there is a compression release on the cam but make sure you have a strong battery a weak battery will act like like a compression problem
1helpful
Craftsman 42in. rider with a kohler 17.5 Was running great, but last time i tried to crank, wouldnt get above a low idle. Now just backfires threw carb. Plug is fireing, compression is 92lbs., getting...
Try adjusting the Intake and Exhaust Valves if this engine is the OHV model. I am also concerned about fuel flow and trash in the carburetor. This machine needs a fuel filter . It also needs a fuel-shutoff valve so that if the needle valve in the carburetor sticks open or gets trash in it to hold it open, it does NOT let all the gas in the tank drain in and overflow into the engines crankcase. I would also drain the fuel, and check the float bowl for water/sediment and debris. If you find that stuff in there, clean it out, and the rest of the carb should be removed and cleaned also.
2helpful
3answers
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
2helpful
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
1helpful
Can you give me a ballpark figure on replacing a head gasket on a older Craftsman riding lawn mower...
there are many variables, since you didn't give any specifics. if it is an older, single cylinder, L-head engine, labor would be roughly 1/2 hour; if an older twin, L-head, about 1 hour; if it's a kohler, add about 1/2 hour; if it's a single, OHV, about 1 hour; if a twin OHV, 1 1/2 hours; if a kohler, add 1/2 hour. each shop has it's own labor rate. flat rate manuals will vary and are not realistic when dealing with old, possibly rusted or frozen bolts, which will increase the cost of repair. a new head gasket will usually cost between $5 to $30, depending on which engine you have. {some older craftsmans had a briggs laid sideways or an onan. these will require a lot more work and the labor would be higher]
4helpful
3answers
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
