Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Problem for Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright...
Hoover windtunnel vaccum U6445-900 motor not
By vmrudrav on May 03, 2009
Hoover windtunnel vaccum U6445-900 motor not turning on. I removed the screws and located the contacts inside. There is an on-off switch which seems to be stuck Is there a way to replace this switch
Comments:
May 04, 2009
- I am talking about the switch which is inside the unit. The outside on/off switch seems to turn on the switch which is inside. The inside switch connects to 2 wires. They seem to be burnt. and the inside switch is stuck and melted. I guess this is what turns on the motor. Can I buy this switch. My model is about 9 years old.
Solution #1
posted on Nov 02, 2009
Not Rated)
Suggestion4U
Rank: Apprentice
Rating: 0%, 0 votes
There are a number of Hoover vacuums that are subject to a recall due to an overheating on/off switch. Check out this web site to see if your is included. You'll need the model number and serial number from the back of the unit. The manufacturer will direct you to an authorized repair center for a free replacement of the defective switch.
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05156.html
Was this helpful?
Yes
No
Solution #2
posted on May 04, 2009
Not Rated)
galati2k
Rank: Wiz
Rating: 84%, 141 votes
i believe that is a fairly new model like 2 to 3 years old.if so on the back where the cord hanger is there are 2 screws take them out,then on the back of the handle there are 2 screws take them out.the handle should slide out towards the back.you can buy the revised switch already in the handle for $28.00.no wiring involved it plugs itself in when you put the handle back on
Comments:
May 04, 2009
- please leave feedback
May 04, 2009
- yes you can order it through hoover or go to a vacuum repair shop and get it through them
Was this helpful?
Yes
No
Popular Solutions for Hoover U6437-900 / U6439-900
Questions and Unsolved Problems for Hoover U6437-900 / U6439-900
Do you recommend Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum?
Answer
Answer
Adjusting the height and brush control do not work. Belts are good. Is there a site where I can see... (More)
Answer
i have ordered the part and recieved it but don't know where to start to replace it.the handle... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover U6437-900 / U6439-900...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
