Question about Nintendo Wii Console
Disc stuckin wii
My wii fell and it had a disc in and now it doesn't come out
Look there's no easy way to get that out I had that happen to me on a ps2 and I removed the cover and got it out,but that voids the warranty .There's no way of doing it with out removing the cover so either take it back or remove the rubber grommets and get out a phillips head screw driver or what ever it uses
Posted on Oct 06, 2007
SOURCE:
My wii doesn't take discs in
The mechanical arms or the insert disc sensor is damaged. The easiest repair would be to have the disc drive replaced.
Apr 06, 2013 | Video Game Consoles & Games
Have a game the wii wont read
Hi, Check and clean the disc. If the disc has too many finger prints it will be harder for the Wii to read. If that doesn't work try a laser cleaner disc. Good luck
Nov 16, 2011 | Nintendo Wii Console
We got a game stuck in the wii consele....We tried ejecting the game as well as turning the game off...nothing is working.
You have to try out all these options first:
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds.
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
If none of this works, you might wanna try this, but it is not a preferred method, if you ask me, even though it can be done.
To remove a disc you'll need three sets of tweezers. And possibly a bobby-pin.
First you need to turn the Wii upside down (and preferably unplugged from a power source)
Second, using two sets of tweezers, press the small metal "guards" down. These are located just inside the mouth of the Wii. They're there to keep the disc from free falling, and inhibit their removal. They aren't locked and shouldn't be difficult to press down.
Third, you'll need to reach "up" through the middle of the mouth with the third set of tweezers to grab hold of the disc. I'd highly recommend using flat tweezers, not sharp ones as the disc may become scratched.
NOTE: The disc itself rests on the internal carriage (through the center hole of the disc) and if upside down, should fall into your tweezer's grasp easily. If it doesn't then you need a bobby pin to dislodge. Gently press the bobby pin on top of the disc and then grip the disc with the tweezers.
Finally, gently pull and the disc and push on the bobby pin and the disc will slide out easily .
This can be done with one person, but helps if you have an extra hand.
Good luck.
Sep 23, 2011 | Nintendo Wii Console
When inserting game disc it says "disc cannot be read. Refer to the wii operations manual."
  1. Refer to the Wii operations manual.
  2. Try cleaning the disc with a lint-free cloth. Wipe the disc in strait lines, not in a circle.
  3. Don't move the Wii around while there is a disc in it. Do this to prevent further damage.
  4. Try a different disc, preferably one that is much cleaner. If it doesn't work, there is an internal error with the Wii.
Jul 12, 2011 | Nintendo Wii Console
Wii console fell and now it wont eject the disc
sometime on consoles there is a small pin like hole next to the drive. a paper clip inserted into this and jiggled around might free the disc to open. works on computers might work for you. but if it fell looks like its f**ked
Aug 31, 2009 | Nintendo Wii Console
Wont eject game disc
From a previous FixYa member:
"I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel."
Dec 29, 2008 | Nintendo Wii Console
Our wii wont read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jul 10, 2008 | Nintendo Wii Console
Cannot Load Disc
you might want to send it to nintendo even though this is probably the last thing you want to do but it will probably be the safest bet for something so small and delicate.
Jun 30, 2008 | Nintendo Wii Console
My wii doesnt play the game discs anymore
try disconnecting the power source and wait 2 minutes then plug back in it should be ok
Mar 17, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
95 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
