Reception
1. check your antenna hook up. Make sure the cable is tight. If your antenna is old, you may have to buy a new one. Also check the cable connection to the antenna, that it is tight. You might want to check take the cable off the antenna and see if it is clean from weather wear. If the antenna is inside you might try moving it outside and to a higher position.
2. if you have cable you need to contact their customer support and ask them to check their transmission to you. They can tell if the reception is getting to their box. They may offer to come out to your house to check the connections inside and check the box. Before they do that, ask what it will cost. I did not ask that question and they charged me $60 and only replaced the cable hooked to the box which I could have done.
3. There are antenna's you can buy that will work inside the house. I have one that picks up stations that are 30 miles away. The stations that far away are not always on or good but my point is that the local stations come in very good and clear.
HTH
Wayne
420 V.34 negotiations have failed from the originating machine during phase 4. Phase 4 occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Solution: Reattempt the fax reception at a different time when telephone line conditions have improved.
421 V.34 negotiations have failed from the originating machine during phase 3. Phase 3 occurs after V.8, before phase4, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
422 V.34 negotiations have failed from the answering machine during phase 4. Phase 4 occurs after V.8 and before the first T.30 frames are exchanged.
Solution: 1. Reattempt the fax reception at a different time when telephone line conditions have improved.
