Question about Pioneer VSX-27TX Receiver
No DTS sound / RESET
Hi, I got a VSX-27TX recently, and this unit is not working with DTS sound. I already have tried many discs on 4 DVD players (configurated to dts), as Panasonic S35, LG DR1F9H, Nakamichi DVD15 and DVL 909 hacked for dts out, but NO DTS sound. Already changed the in coaxial/optical digital ports 1 to 4 to DVD/LD and TV/SAT modes, with digital and auto signal select. No sound, only a low noise "tick" on L/R front speakers (the light on panel shows front L/R for DTS only). The big DTS display on panel not appears, only the tiny beside the speakers indicator. Dolby Digital is working fine. Maybe there is a reset for this receiver? My old D906S have the reset botom. I will thank a lot for any tip or the definitive solution.
  • thexder Oct 07, 2007
    Well, I have solved this problem :)
    I replaced the condensers arround DTS circuit at DSP board (C9393, C9383, C9376, C9372, C9360, C9343) and now all working fine!!
    Thanks for Miguel in post a tip for this.
    Problem Solver:
  • 12 Answers
Hi I have a Pioneer VSX D908S which is basically the same amplifier as yours with the difference that the one I have has no THX certification, as a matter of fact the service manual is the same, and mine has the same problem. The prblem is located in the DSP board, if you are able to remove the bonett, you will see on the right side a metal cover, remove it, once you have removed it, look for a IC9374 it is located, -looking this board in front to you- almost at the left upper corner, this IC has the PDK042A on it, with a soldering iron resolder this circuit. This is common problem with this pioneer amplifiers, and this procedure not always works, the final solution is to buy the DSP board but it is expensive. Good luck! Miguel
Posted on Oct 06, 2007
Unlock Sony BDP-S1200
Have you been playing cd etc from different countries. The cd units in this country will lock you out after about three tries, that is the law.
Dec 19, 2014 | Sony BDP-S1200 Blu-ray Disc Player - 1080p...
you can locate the R9371 & R9374 beside or the same circuit of the IC 9374 Very near not far to IC 9374.
Nov 22, 2007 | Pioneer VSX-27TX Receiver
My surround sound won't work now when I play the dvd player
Could be many things - I know, bad answer. There is no simple answer or fix.
Without more info one can only speculate.
Please determine and answer as many or all of the following so that we can help.
1) What is the make and model number of the Surround sound unit?
2) What is the make and model of the DVD player?
3) How is the DVD player connected to the Surround sound unit?
3a) Is it connected via an HDMI cable?
3b) Does the DVD player have regular stereo connections that you are using (we call these analog audio connectors)?
3c) does the DVD player have digital audio outputs that are connected to the Surround sound receiver?
4) Did the DVD player EVER make sound?
4a) if yes - what changed?
4b) if yes - does this happen with different discs?
Now some general points.
I'll assume that the other sources do work and play sound through all speakers when they are supposed to play sound through all speakers.
Then - I'll assume that without changing anything else you select the DVD player input that used to make sound but doesn't now.
Problem could be the encoding option that you have selected when you play the disc.
Many DVD's and Bluray's have audio options that you can select from the disc's main menu.
Dolby digital is the most common - also known as AC3.
Some discs have another digital audio track called DTS.
Not all surround receivers can decode all formats.
Even if your surround receiver claims to be able to decode AC3 and DTS, they will not if you don't connect the correct cable to the receiver and usually map the input to the correct digital audio connection that you are using OR if your DVD player is not capable of outputting all formats.
There are many different ways to connect the gear and many different ways one can configure correctly or not; all contributing to whether you get sound or not.
So in the above example - by selecting DTS, you do not get any sound - then try another audio track option. Basic stereo usually works (also know as PCM - which is audio like a CD).
OR maybe you never properly configured the audio properties of the DVD player.
Go into the DVD's menu or set up options and see what you find but make sure you know how the DVD is connected to your surround receiver!
As you can see - there is no simple answer without a lengthy Q and A exchange first.
May 26, 2014 | Yamaha Audio Players & Recorders
How to make aSAMSUNG HT-F6500W region free (hack-code) as I am an expat
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the cThere isn`t currently a region hack for Blue-Ray Disksorner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
Dec 24, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
My techwood tv will not play sound and the colour is not right. how do I fix this?
see the charts troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
Try a direct connection from the DVD player to the TV set, instead of via other components.
Oct 14, 2013 | Gemini 1 Device Universal Television...
No picture, no sound
see the troubleshooting index:God bless you
No sound
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Sep 23, 2013 | LG 32cs460 32" Inch Widescreen 720p 60hz...
Everytime I use the DTS functions to enable my surround sound, no sound goes to my speakers. I am able to use it only for the standard output with the left and right front speakers. What could be causing...
DTS should be enabled only if your source has a DTS digital audio out connected to the receiver.Mostly only DVD / Bluray players have DTS sound and is outputted through an optical or co-axial port on the back of the player. Its a multichannel digital encryption technology where the signal is sent through one cable and your receiver decodes it into 5.1 or 7.1 channels according to the source.
Apr 22, 2011 | Pioneer VSX-D810S Receiver
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
I am trying to record to a blank dvd-r. I load a
If exact model is Samsung DVD-VR357, than it doesn't even has to recognise blank disc as your unit is DVD PLAYER with Video Casette Recorder.
See Specs. for your unit below:
Function Combination VCR Y Compatibility Playback Media DVD-R,DVD-RW,DVD+R,DVD+RW,CD-R/RW,CD,VHS, DVD-RAM Playback Formats MP3, WMA, JPEG, MPEG-4, DivX A/V Quality Progressive Scan Y HD Upconversion 720p/1080i Digital-to-Analog Converter 10-Bit/54MHz DTS Output Y Dolby Digital Surround Sound Y Connectivity HDMI CEC Y Convenience Child Protection Parental Control Physical Features Connectivity HDMI Output Y Component Video Output 1(Rear) S-Video Output 1(Rear) Composite Video Output 1(Rear) Coaxial Digital Audio Outputs 1(Rear) Optical Audio Output 1(Rear) Product Weight & Dimensions Dimension 16.9" x 3.1" x 11" Weight 8.8Lbs. Shipment Weight & Dimensions Dimension 20.2" x 7.1" x 15.1" Weight 12.1Lbs.
Closest model match for DVD recording unit would be DVD-VR375
Unfortunately you have player only and you won't be able to recor DVDs with it whatsoever.
Good luck
Jun 24, 2009 | Samsung DVD-VR357
Sibilant output from Pioneer VSX 1018 AH-S
Suspect a DTS board capacitor failures the ESR characteristics.
To troubleshoot connected any available device to RCA stereo connections at input to multi channel in. Test input to the corresponding speaker output confirming audio quality. This circuit bi-passes the DTS function and connects to the power amplifier for the speaker.
Connect any audio amplifier from the preamp out and confirm the quality of the audio.
I suspect that the pre-amp out will contain the distortedf noise. If the distrotion appears in all the channels it is most likely the DTS.
These are repairable.
Hope this helps?
May 09, 2017 | Pioneer VSX-1015TXK Receiver
Pioneer VSX-27TX Receiver Logo
522 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
