Zenith Dual receiver PIP 27 " standard "portable" TV color problems
The color is starting to fade, the picture getting darker and losing the blue - both green & blue come up green. Since I can't find any new TVs with dual receivers & Pip ( Picture In Picture ) I would rather repair this old faithful - than give up my PIP.
  • 1 more comment
  • sammygayle Oct 08, 2007
    Tell me something I asked and don't already know
    What can you do to correct / fix this ? Is it a matter of purchasing/ replacing tubes, ckt boards etc ? Can you reccommend anyone to do this ?
    Also, if I adjust the red in the color control menu to a higher setting - everything becomes too red, so I am a little confused as to the "lack of or poor quality " red -
    The set gets swiveled on a turn table - how can you tell if the crt is loose and how does it get tightened ?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
From sympton it looks to me that you should go for new one.
Posted on Oct 07, 2007
  • Anonymous Oct 08, 2007
    1 The color is starting to fade& dark.
    it is due to low brightness & it is due to video section supply not proper or less voltage on g2 electrode.& FINALLY DUE TO WEAK CRT.
    2 losing the blue - both green & blue come up green.
    green +blue =cyan as you said looks like green
    this is due to red colour absent.
    red absent is due to
    1 crt base loose.
    2 failure of red video circuit means supply to red video not proper or parts failure in red cathode ckt.
    3 connector loose (RGB)
    4 red signal is not coming from processor to red video section.
    means your problem is in red video section &also as per you crt is getting weak.
    hope this is enough.
    good luck.
SOURCE:
I have blue purple and red colors through my tv
that means that your tv picture is fixen to go out
Nov 11, 2009 | Zenith C27A24T 27" TV
DVD connections have progressively grown darker and now have gone to totaly black and white. Television color and picture are completely normal.
If you are using the red,green and blue component inputs, check to make sure the red and blue ones are connected good and none of the jacks are loose. If not there is a problem with either the DVD player or the TV. Hard to say. Thanks
Oct 28, 2009 | JVC AV-27D203 27" TV
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Zenith 27" HDTV second antenna input not accessible on TV/remote
Hi and welcome to FixYa,
Pls verify if your particular model/versions has a PIP feature. To my understanding, the 2nd Antenna/Cable IN goes to a 2nd tuner that is primarily used for the PIP (picture in picture) mode. This mode would allow you to watch simultaneously 2 different TV channels.
Pls post back. Good luck and thank you for using FixYa.
Feb 10, 2009 | Zenith C27V36 27" TV
Zenith System 3 Model # SR2571DT
if you know how to solder , then resolder your tv ,maybe your tv had a lose connection.
Oct 12, 2008 | Zenith C27A24T 27" TV
Old zenith 36"
Bad CRT (the picture tube) they fail on the many of the zenith sets.
Jul 26, 2008 | Zenith C27A24T 27" TV
Durabrand 27" TV
the problem, lies on the flyback ,, on the flyback there two adjustment, the screen and focus that was writtten , adjust only the screen slowly untill screen of your tv back to normal.....fading because over saturation of voltage, adjust the screen trimmer counterclocwise....
Feb 23, 2008 | Durabrand DWT1905 TV
Pip for my iQB36B44w
The PIP may only work with an external tuner or source (VCR, DVD, CATV box, etc) If your TV doesnt say "dual tuner" then you need an external source for the PIP (Use a VCR and its tuner for instance)
Feb 13, 2008 | Zenith B27A11Z 27" TV
Problem with the color on my Zenith
picture tube need a picture tube reguvinator $1300
Apr 29, 2007 | Zenith C27A24T 27" TV
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Ekse
