Question about Panasonic PV-C1321 13 in. TV/VCR Combo
Cable connection doesn't hold and picture starts flipping - we wiggle it a bit and it works for a while and starts flipping again. What is the problem?
The v hold is going out that causes the picture to roll if only 1 channel does that then call the cable company.If it's more than one then find the v-hold in the back and turn it slowly till it stops,if it gets faster turn it the other way
Posted on Oct 06, 2007
No sound in left headphone
Yes, sure. But it's a bit difficult, because you have to find the broken piece of it. Look for cuts in the wire. If you can see it, you can cut the protecting piece over the wire open or off and connect your wires again. Melt them together and it should work.
Jan 02, 2014 | Wesc Bongo Headphones
I have a 2005 nissan frontier that I changed the battery and now it starts but shakes and then sometimes starts
If it doesn't start every time I would double check for loose connections on the battery terminal. When it doesn't start, try wiggling the battery connections and try starting it again. Then you would want to fix the loose terminal connections. The spark plug gap does seem to be a bit big. I would just make a phone call to your local auto part store and they can tell you the exact gap that it should be.
Nov 13, 2012 | 2005 Nissan Frontier
Car dies, battery good, wiggle the + cable, we can start again
Make certain that the cable is snug on the terminal. you should be able to hold it with your hand and not move it. You can try replacing the cable, but if that doesn't remedy the situation, then it is DEFINATELY the battery. A battery that old is on the verge of failure!
Apr 29, 2012 | 1992 Pontiac Grand Am
Turns over wont start plenty of gas
I would check the fuel relay and see if it has a good connection. Chances are it doesn't just pull the relay out and put it back in and wiggle it around a little bit. That will tell you if your fuel relay has a bad connection.
Nov 18, 2011 | 2005 Chevrolet Malibu
I went from XP to windows 7 64 bit and now my cyber-shot camera is not recognized when I try to download pictures. Sony couldn't figure it out.
If you connect CyberShot Camera from a USB Cable, check the cable once. If that doesn't solve the problem, Choose Mass storage option from the Camera Menu when prompted. I think it should work.
Nov 11, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Won't start up message says: PXE-E61 Media test failure No bootable device
This can easily indicate a Hard Drive failure, or, it could be that the drive wiggled loose. When the power turns on, tap F12 several times which should open the "Boot Menu". This list should display all of the devices you can have the computer attempt to load an operating system from. If the Hard Drive is missing, or doesn't work when you hit "Enter" it could be the fault of the drive. You can try flipping the laptop over, grabbing a small screwdriver, and unscrewing the bay on the bottom that has a picture of a cylinder next to the screw holes. Slide the drive out, and then back in, screw it all back together, and try it again.
Aug 23, 2011 | Toshiba Satellite Pro L300 Notebook
Wont turn on
The most common reasons are your batter and power adapter.
Disconnect all cables, flip the laptop, unlock and remove the battery. Reinsert and lock, connect the power adapter and try again.
If still a problem, disconnect all cables, flip the laptop, unlock and remove the battery. Connect the power adapter again. If it works, your battery is faulty and needs replacement. if it doesn't work and there is no light on the adapter, your adapter is probably faulty.
Also, try this: wiggle the power adapter where it connects to the laptop. If the power goes on and off, the power jack is faulty and needs soldering or replacement. Leave that job to an experienced tech.
Hope this helps.
Dec 02, 2010 | Dell Latitude D600 Notebook
Same- get audit, no picture. HELP!!
It has to be something wrong with either the connection from the DVD video cable (yellow if your using composite av cables... green, blue and red if your using HDMI cables, or black with a round connector with little pins inside if using S-video), check on both the back of the DVD player where the cable comes out, and also on the back of either the TV or the receiver unit where the Video cable connects. If your cable goes from DVD --> Receiver --> TV, check both cables inbetween to ensure that they are tightly connected. Turn on your system as if your trying to watch a DVD, and when you hear the sound, wiggle the cables and see if you get a picture (having someone else wiggle and you watch or vice versa will be the easiest). If nothing comes up, then perhaps a cable is bad. Try replacing the cables with new ones, try the system now. If the cables didnt solve the problem, again, repeat the process of starting the DVD and then wiggling the cables. If still no picture, it might be internal issues with the connectors themselves. If your handy, you can try to take apart the devices and trouble shoot... but I would suggest calling Bose (or the companies that make your TV and DVD players) and see what steps they suggest you take.
Aug 10, 2009 | Bose Lifestyle 25 System
Jumping mouse cursor
Elsamma, If you are positive keeping the cable stationary prevents the problem try this: Try holding the mouse connector stationary and wiggle the cable. If the problem occurs then the connection between the mouse connector/cable is defective, due to the low value of this mouse the fix would typically be replacing rather than repair. If that doesn?t work try wiggling the mouse connector where it plugs into the PC. If this causes the problem to reappear then either your mouse connector or the PC socket is damaged. Try another mouse and if the problem goes away, again the fix would be to replace the mouse. If a new mouse doesn?t fix the problem then there is a good chance the PS2 connector is damaged. At this point I would purchase a USB mouse which should solve your problem Let us know how things go and if you need any more assistance.
Jul 11, 2007 | Logitech -9536890403 Mouse
Panasonic PV-C1321 13 in. TV/VCR Combo Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
