Question about Dishwashers
Cannot open the dishwasher door !
I just bought an ASKO 3132 dishwasher. It has just been delivered, no manual or instructions outside the machine. It remains unfitted. I cannot get the door open prior to fitting. I have tried this with power on/off and the 'under handle' child lock on/off. I have looked up the online manual to no avail. Any suggestions?
  • 1 more comment
  • Anonymous Jul 05, 2008
    yes hoave u figured how to opn it yet?
  • motocross123 Nov 02, 2008
    Dacor 30" just delivered...door latch will not release...no instructions on the oustide how to release latch...also plugged in and tried to manipulate bottoms to no avail...instruction manual is INSIDE dishwasher! So I read the complete manual online...no help was provided...
  • Anonymous Dec 01, 2008
    I cannot get my door open! andYES I pulled onthe latch.
I had the same problem and found that the door henge was loose on the right side. By lifting on the door and then pulling out after lifting the door opened.
Posted on Feb 12, 2009
Is there a catch that you can squeeze? on the front of the door?
Posted on Oct 06, 2007
SOURCE:
Controls don't work after ASKO W660 "fault indication overflow"
Check that water has not got into the very bottom of the machine. Many machines have a drip tray that will shut the machine down if water is present to reduce the risk of f
Nov 09, 2013 | Asko 24 in. D3120 Dishwasher
Asko D3530 Dishwasher Water Inlet Fault
I did research on the net and asko mention a special settings menu in the pdf manuals available
you can download a manual but there is a reference to water not entering the washer in the manual and how to trouble shoot it
Pressure pumps deliver water at pressures from 35 psi to 60 psi and if you have checked all of the slow fill reasons , maybe checking the on/off pressure switch for the pump would be a place to investigate
the machine will start when the water has reached the level set
anyway go google and type in - workshop manual for asko dishwasher model d3530 --and download a pdf version to read
Jun 08, 2017 | Dishwashers
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
ASKO 1605 Dishwasher instruction manual
Hello & Welcome to FixYa
You can download the manual for your Asko unit here. Please get back to me if you have any other questions.
Kevin
May 14, 2011 | Asko Dishwashers
My dishwasher is signalling F2 but there is no water in the machine. When I start the dishwasher, it starts correctly but then very shortly starts the F2 signal. When I open the door, the dishwasher does...
Do you have a user manual for this dishwasher.
F2 is linked to either water intake or drain pump problem. Please confirm what you mean by "dishwasher does not stop". If there is no water inside what is the dishwasher doing when you open the door.
Nov 26, 2010 | Asko D1776 Built-in Dishwasher
Manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Apr 24, 2010 | Dishwashers
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Dishwashers Logo
970 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
