Sony TA-F210 amplifier no sound
Hi i have a sony TA-F210 , with no sound. The power is ok. I opened it and checked some things but didn`t find something wrong yet I am a beginner in electronics. I checked the power on the driver ic`s and it`s not good. its very low 2 volts. The power rectifier and power controller ?c`s are working (7815 and 7915). The relais works also. I don`t know why the driver ic`s get very low voltage. But i`m only a beginner, i am stuck now. Anyone has a solution or tip? Thanks!
  • Anonymous Oct 13, 2007
    i let you know if i find a solution :)
Check R803 and R804!!! They must be 0.33 Ohms. When they are more check the capacitors.
Posted on Apr 27, 2008
  • 682 Answers
Bring data sheet of this ic from the net-check supply voltage(vcc or vdd)-check ground.apply audio signal and test if it is present in input pins after that check your signal in output pins.have a visual inspection around the ic for burnt resistors or bad capacitor. if every thing is fine replace the IC.
Posted on Mar 11, 2008
SOURCE:
Sony TA-N9000ES Power Amplifier Problem: I have a
I have just purchased a Audiosonic Soundbar KW-3508 and connected it up to an existing cetre speaker connection but could get no sound.Any suggestions?
Aug 04, 2013 | Sony Audio Players & Recorders
I haves an amplifier SONY TA-F210 to repair. The four "final" transistors are take out and miss. I haves no ideas of witch kind of transistors need. Please I need the list of component (or the...
You can download the manual included schematic diagram from here:
http://elektrotanya.com/sony_ta-f110,f210.pdf/download.html
When you use the link you get to a page where you have to wait some minutes to be possible the downloading.
Thanks.
gylacz
Aug 04, 2011 | Sony Audio Players & Recorders
My digital amplifier S-MASTER,mod HDC-SB300 just 5 seconds after I turn it on swithes off by itself and the standby light keeps flashing and the display stays off and i can do nothing..thanks
hi,
may be ur amplifiers any of the output channel have some problem. that's why it goes off after power on, protecting ur speakers. disconnect all the speakers and inputs and then power on it if works check ur speakers and inputs. if not there is fault inside ur amplifier.
ok
Dec 22, 2010 | Sony TA-N9000ES 5-Channel Amplifier
I have just bought a used Sony Integrated amplifier TA- F210 and it didn't come with the owner's manual so I don't know the RMS wattage to enable me connect speakers with the appropriate wattage. Could...
Hi, I brought a Sony TA-F-210 new back in 1990 $ 650 NZ , and has been a very .. very good amp. Earthquake ruined it !! I still have the owners manuel and it says for UK and other countrys DIN, 1 kHz, 8 ohms . 70w + 70w . or . 20Hz-20kHz THD 0.05%, 8 ohms . 50w + 50w Hope this helps. Have been running big old 3 way 8 ohm 50w speakers for all its life and it grunts.. or did !! Nobody belived me I was running only 50w speakers !! I dont know what I will replace it with.. You will enjoy. Might look for another one ! Wayne.. NZ CHCH
Nov 26, 2010 | Audio Players & Recorders
I accidentally plugged my 110V amplifier to 220V outlet.It has no power anymore.what possible solution for this. Thank you very much. Do I need to replace the rectifier in it's circuit?
Hi and welcome to the site,
Initially, on a completely dead Sony TA-N9000ES, primary suspects to be checked would be:
  • 8A F1 fuse;
  • primary winding of T1 transformer;.
  • fusible resistors R816, R817 and R818.
Good luck and thank you for asking.
Jul 13, 2010 | Sony TA-N9000ES 5-Channel Amplifier
Sony TA-E9000es. No Display, No Sound. Software Ver 1.18. Has Bulletin HIFI1-99-028R1 performed. (Add capacitor, replace resistor)
also replace Q108 @ Q109 on power board. If that does not fix it then also replace PH101 & PH102. Also on Power board.
Jan 14, 2010 | Sony TA-E9000ES Amplifier
Sony preamp has no speaker output but headphone jack work fine
Hi...
If this thing is a pre-amp , it will not drive any speakers.
You'll need a power amp to connect the output of the pre-amp to...then speakers.
PLease rate my help ...Thanks
Scott
Mar 22, 2009 | Sony Audio Players & Recorders
1,312 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
