Question about Kyocera Slider Remix KX5 / Sonic Cellular Phone
Phones ear speaker stopped working?
I can't listen to calls or anything unless i plug in the head set or use speaker phone cause the ear speaker stopped working? Can anyone help?
  • 2 more comments
  • technoluv Jan 18, 2008
    My Slider did the same thing with the earpiece no longer working. I also have to use the speakerphone or headset to use the phone. I went to the phone service provider and they said they have never heard of that before, however I have seen this many times from other owners on line. Any Help out there?
  • nvr_luz Jan 23, 2008
    i have the same problem.. i went to go get it fixed but they would charge me $65. They also said that it happens to alot of these phones and later the screen is gonna go out
  • juliern Feb 23, 2008
    My ear speaker recently stopped working as well. Everything else seems to be working fine. Anyone have any suggestions?
  • Anonymous May 05, 2008
    I can't hear on my earpiece either, only through speakerphone or headset...I tried the suggestion but when I go into the music player, it says no file present in card and phone, and I can't go further. any other help?
    Problem Solver:
  • 15 Answers
I guess this is a common problem huh. No worries!
First: Click on your music button and play a song as you would normally do on your phone (make sure your speaker is on during this point).
Second: Click on the speaker button so you can listen to your music through your ear piece (as your music is still playing). If you don't hear your music through your ear piece wait until you hear it. It shouldn't take more than a minute. (Your music should be playing throughout this whole process)
Follow these steps every time you come across this problem.
If this solution resolved your problem, please leave a comment and a good rate. Thank you!
Posted on Mar 15, 2008
When I receive an incoming call I have to put them on speaker or I can't hear...same with outgoing calls....
The main reason for this problem is because of the ear piece. The ear piece is something you keep close to your ears while making calls. The speaker is an alternate way to listen music or to listen the caller loud or for ring tone.
Check your ear piece. Either it would have damaged due to water or would have lost the connection to the circuitry.
May 19, 2011 | HTC Cell Phones
Can't hear call from the ear piece only on speaker
There could be a Three problems. In all cases you have to get it serviced.. Cause no.1_ Your ear speaker has stop functioning. Cause No.2_ There could be a connection loss with ear speaker. Cause No.3_ IC which looks after ear speaker has stop functioning..
Hope this has helped you.. Please rate the answer. Thanks
Jun 23, 2010 | LG CU515 Cellular Phone
Ear speaker not when slide is off.when on its working
Hi, What controls the ear speaker of Nokia 6280is the flex of the phone.
The flex is connected to the board of the phone and it also allows the screen to display. It flex enables the ear speaker to function. So what will make the ear speaker work better is too replace the flex of the phone because it's weak .
After replacing the flex, every thing will work normal.
Take care.
Jun 15, 2010 | Nokia 6280 Cellular Phone
I have a set of 4 Altec Lansing surround sound speakers with a subwoofer i bought in 2003 with my dell computer. I can't get any sound from them. Do you have any suggestions? I tried hooking the system up...
If you are listening through headphones that are plugged in to the Altec system, then your problem is the amplifier is bad. Can't help you online with that. Sorry!
Feb 24, 2010 | Altec Lansing Multimedia Computer Speakers
Sony Ericson C905 Speaker problem
This Problem Is Caused By Either Haveing Put In A Ear Piece Or Blue Tooth Head Set Inwhich Case You Should Be Able To Plug It In And Remove It Again And Your Problem Should'nt Persist
Nov 01, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
I can't turn of this handsfree thing in my phone..
During phone call, do you see a 'speaker' icon you can press in the screen? It only shows when a call is active. It toggles between handsfree and fry-your-ear mode. If you are listening with the loud speaker and plug in your wired headset it will automatically go off speaker mode (takes a couple of seconds to work). You can put it back into speaker mode while the headset is still attached.
On mine, it remembers the volume I last used with the speaker, so if you had the volume down you can adjust with the up-down buttons on the right hand side of the handset.
If you have an older storm, I think the volume buttons have sometimes been reported to have problems. Whether you can fix that will depend on whether you are under a service contract for handset warranty or maintanance.
Sep 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
I cant answer my phone properly
as it will be set on the ear phone mode or the internal speakers got malfunctioned.just remove the battery of the cell  after turning it off .then insert after couple of minutes and check out.it many a times gets resetted.
Jan 30, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Volume control
the ear piece may be dead or if its a flip phone check the flex cable
Nov 29, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Razr speaker problems
Dear sir
my cell phone in comming and out going call speeker doesn't work but my spoker on work voice bad.spoker off feel nothing. i am live in texascity.TX 77590 where close me service center please fix this problam.Thank you.MANI.
Oct 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
May 30, 2007 | Motorola Mobility RAZR V3
Kyocera Slider Remix KX5 / Sonic Cellular Phone Logo
429 people viewed this question
Top Kyocera Cell Phones Experts
Jim LeVerso - IT...
Jim LeVerso - IT...
Pierre Legault
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
