Question about LG 42PC3D 42 in. Plasma Television
Picture is cut off at top and bottom
The top and bottom of the picture are cut off. I have tried all the aspect ratio settings on the remote and still have the problem.
  • 86 Answers
Push the "Ratio" button on the remote
Posted on Jan 22, 2008
SOURCE:
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Picture is cutting off top of subjects head. Can't see wording at bottom on screen
The aspect ratio is not set up right. It is a menu thing and you will have to make the change on screen with your remote. Find the list for the picture and go through the menu, look for aspect ratio or screen size.
Feb 09, 2010 | LG 32LG30 32 in. LCD HDTV
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Top and bottom of picture are cut off
Sounds like you may have the aspect ratio setting wrong,look for a button labeled aspect,ratio,wide any of these on your remote then press multiple times until you get the picture formatted the way you like it.If you have a satellite receiver or a digital cable box they also contain an aspect ratio adjustment in their menu system so you may need to check there also. Good luck !
Nov 26, 2009 | Toshiba Televison & Video
My picture on the LG 37LC7d is too big for the screen the top and bottom are cut off how can I fix this
You need to adjust the aspect ratio, look for button on remote called 'ASPECT', 'ZOOM', or 'SIZE'.
You can download your TV user manul here, it will explain how to set aspect ratio.
http://tv.manualsonline.com/search.html?q=LG+37LC7d+&submit.x=27&submit.y=14
Nov 14, 2009 | Televison & Video
Sony bravia loosing the top and bottom of picture.
Try the aspect ratio button on the remote or it is possibly an on screen aspect adjus
Aug 08, 2009 | JVC LT42P789 42 in. LCD TV
The bottom and top of the picture are being cut off
Check your remote for a "zoom" or "picture size" button. Press this button to adjust the size until everything fits back on the screen.
Please take a moment to rate this solution a fixya if it's helped with your problem. Thanks for asking here!
Mar 21, 2009 | Vizio L32 32 in. LCD HDTV
Picture is cut off
Try setting the set to 4.3 expanded on the aspect ratio. If that don't work try the other aspect ratio settings. That should make the picture fit the screen.
Jun 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Picture quality is terrible...not sharp and crystal clear
Set the aspect ratio to 16:9 and the top and bottom of the picture will reurn. Promise.
Try adjusting your contrast to help the filmy looking picture.
Dec 09, 2007 | Sylvania LC370SL8 37 in. LCD Television
LG 42PC3D 42 in. Plasma Television Logo
389 people viewed this question
Ekse
