Question about Norelco Advantage 6705 X Electric Shaver
Battery replacement How do I remove and replace the batteries?
  • 1 more comment
  • arachkid Oct 08, 2007
    No, there's no such thing. I've had the back piece off this shaver, which is held on by two tiny torx fasteners. The problem is to actually remove the batteries which appear to be soldered to a small circuit board. I already have a replacement set from Norelco which has a tab for soldering. It appears that the circuit board would have to be completely removed from the body of the shaver to do the desoldering and resoldering. This is the point at which I need advice from somebody who has done this before.
    Replacing batteries in a Norelco 6705 shaver:
    No, there's no such thing as clips holding the back on. I've had the back piece off this shaver, which is held on by two tiny torx fasteners. The problem is to actually remove the batteries which appear to be soldered to a small circuit board. I already have a replacement battery set from Norelco which has a tab for soldering. It appears that the circuit board would have to be completely removed from the body of the shaver to do the desoldering and resoldering. This is the point at which I need advice from somebody who has done this before.
  • arachkid Oct 10, 2007
    Well, what I'm looking for is advice from someone who has actually replaced these batteries. The soldering is no problem for me. I just don't want to break the circuit board by forcing it out of the shaver body. I don't see anything holding it in place, but it's firmly attached.
  • 363 Answers
If as you say the circuit board needs removing, then won't this just pull out with the battery or is it fixed with more screws? It could be that the battery is folded down over the board after soldering in the factory. Alternatively perhaps I didn't understand the question and you need assistance with soldering?
Posted on Oct 09, 2007
  • Martin B
    Martin B Oct 10, 2007
    OK perhaps even more disassembly is required. Are there any screws on the other side? Wiggle the board to see where it is fixed. But obviosly take your time not to break it!
  • 790 Answers
Is there a sticker at the back of shaver? try to checkout the hole at the sticker, that is the screw, or you can open the unit by unlocking the side locks by cliping out the locks!
Posted on Oct 07, 2007
How change battery on irobot 655
The battery replacement procedure is the same for 500 and 600 series.
  1. Remove the side brush screw and side brush.
  2. Remove the 4 screws to remove the bottom cover.
  3. Remove the battery.
  4. Install the replacement battery, with the iRobot logo facing up and charge overnight.
More items...
Replacing the Roomba 500 and 600 series battery. - iRobot Customer ...
https://homesupport.irobot.com/.../replacing-the-roomba-500-and-600-series-battery.
Feb 04, 2018 | iRobot Vacuums
How do I remove the battery on a 2008 ford escape?
There is one bolt at the base of the battery that holds a wedge that retains the battery to the battery tray, remove it.
Aug 23, 2012 | 2008 Ford Escape Hybrid
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
How do I replace the battery on a 2001 Suzuki Volusia Intruder?
To replace the battery:
1- remove the rear (passenger) seat by removing the single bolt behind it. Remove the seat by lifting it up and back
2- Remove the front (driver's) seat). Remove the two bolts behind it and remove the seat by lifting it up and back.
3- Removing the seats will give you access to the battery under the driver's seat.
4- Carefully remove the positive and negative battery cables from the battery, then lift the battery straight up.
5- Place the new battery in the bike
6- Replace the cables, red is positive (+), black is negative (-)
7- replace the seats, and you should be good to go!
Apr 19, 2011 | 2001 Suzuki VL 800 Volusia
How do you remove the battery housing to replace the battery
just left of the battery housing are two bolts one holds the other will lower the battery box so you can take the cover and side off, to replace the battery remove the neg. cable off bike then remove pos. off battery pull battery out then remove neg. off battery
Apr 11, 2010 | 2001 Harley Davidson FXDL Dyna Low Rider
Any special instructions for replacing the battery in my 2007 Azera Ltd? I don't want to fry a circuit
easy way to replace the battery, is to undo the battery harness that holds in into the vehicle, then using a 10 mm spanner, undoe the terminal bolts, if you have a coded stereo, then i would advise to either look and make sure you have the code, or, using either jump leads from another vehicle, connect them to the neck of the battery wires, thus supplying a continuous supply so that the codes are not lost. then remove the leads from the battery on your vehicle and remove the old battery. replace with a new battery, tighten up the terminals and replace the battery harness. remove the jump leads and there you have replaced the battery
Mar 17, 2010 | 2007 Hyundai Azera Limited Sedan
I need to replace the onboard battery
If by on board battery you mean the cmos battery, then you would only need to replace it if your computer is constantly forggetting or losing the correct time and date..
If it is doing som the onboard battery is round and flat ( like a watch battery) and is usually accessed either under the keyboard, or by removing one of the plates on the bottom of the laptop..
Make sure the main battery is removed and the power cord is removed before replacing the onboard battery.
Oct 29, 2009 | Computers & Internet
PASSWORD
Remove the RTC battery for at least 15 monutes then replace. Get into BIOS and reset date and time. Removing the Coin-Cell Battery
  1. Follow the instructions in Before You Begin.
  2. Remove the hinge cover (see Removing the Hinge Cover).
  3. Remove the keyboard (see Removing the Keyboard).
  4. Insert a plastic scribe into the guide on the side of the coin-cell battery compartment, and pry out the battery.
Replacing the Coin-Cell Battery
  1. When you replace the battery, insert it at a 30-degree angle under the clip with the positive (identified by a plus [+] symbol) side up, and then push it into place.
  2. Replace the keyboard (see Replacing the Keyboard).
  3. Replace the hinge cover (see Replacing the Hinge Cover).
Oct 02, 2009 | Dell Inspiron 1501 Notebook
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Norelco Advantage 6705 X Electric Shaver Logo
95 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
