Question about Garmin GPSMAP 60CS GPS Receiver
Questions about 1gig sd card
1. How can I check to see how full my SD card is and generally can a full states citynavigator and topo fit on a 1 gig card? We live in CO. 2. When I load a new TOTO area of the state I seem to loose city maps & other saved TOPO's. Then I have to play around with HIDE/SHOW and sometimes it all comes back. Normal? Thanks a bunch!
The way I do it is us an adapter that firs in your card slot on your computer. you can bring it us and show properties. It will tell yopu haw much info you have on your card. The other question. I have the whole city navigator on a 2GB card. It takes up about 1.6GB. So you will not be able to fit it all on a 1GB card.
Also, if you use the adapter it does not take as long to download the maps as it would if you went through your gsp.
Zeb
Posted on Jan 29, 2008
SOURCE:
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
I cannot locate topo maps loaded via sd card
If you have the TOPO maps loaded to an SD card and the card is inserted all you should have to do is go to Tools > Settings > Map > Info in this menu you will find your map sets if you see TOPO make sure it is activated if not you may need to re install them to the SD.
Hope this helps!
Feb 12, 2011 | Garmin nuvi 1490T GPS Receiver
My acer 3680 laptop wo't read a 4 gig hc sd card
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
Oct 05, 2009 | Acer Aspire 3680 Laptop
Garmin Maps
No, Garmin maps will not work on a Magellan Triton.
Yes, you can install Bluechart and CityNavigator onto one SD card. Inside Mapsource, select the Bluechart maps you want, then switch to CityNavigator and select the maps you want from then, and then send all at once to the GPS unit. If you send Bluechart maps, and then CityNavigator, the CityNavigator will overwrite the Bluecharts. This is why it must be done all in one step.
If this solves your question, please remember to come back and rate the answer.
Apr 21, 2009 | Garmin GPSMAP 76Cx GPS Receiver
SD card slot nothing happens
Sounds like it is defective I just came across 2 bad scandisk cards both 2 gig.
Jan 26, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Memory is full
You can only use a 2GB SD card. It is in the manual. I'm not sure on dvd.
Oct 24, 2008 | Mitsuba DV9002 Flash Media Camcorder
LEXAR MICRO SD CARD WITH LG CU 500
I have found that only my 1 gig Micro sd card works, I also have a 2 gig and it does not recognize it at all. I have been told the CU500 only supports up to 1 gig.
Jun 05, 2008 | LG CU500 Cellular Phone
Izone 550 senses SD card, but won't accomodate or write to it...
I would suggest the format option in the menu. i posted the manual it gives step by step getting to the format option. if it works on one but not the other even after formatting in problematic camera. I would suggest getting a different brand/size. There's a 1gig liimit, but i am currently using a panasonic 2 gig and it seems to be working at its stated size. Although i haven't filled it to see if any problems occurr.
Hope this helps.
Dec 27, 2007 | Polaroid izone 550W Digital Camera
Camera does not recognise 1Gig SD Memory Card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Dec 03, 2006 | Rollei Prego DP5300 Digital Camera
    Open Questions:
    See all Garmin GPSMAP 60CS GPS Receiver Questions
    Garmin GPSMAP 60CS GPS Receiver Logo
    54 people viewed this question
    Top Garmin GPS Experts
    Marvin
    Marvin
    Jean-Luc Steffann
    Sheldon Dedek
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
