Question about Garmin StreetPilot c550 GPS Receiver
Screen says memory full and it won't map a route! GRRRRRRR
Please help!! I use my Garmin C550 for work and can't live without it! It tells me the memory is full, and it can't map a route. How can I fix it?
  • 3 more comments
  • nursemeems Oct 06, 2007
    I didn't do the hard reset, but I did do the web updater, the problem seems to be fixed. Thanks!
  • kenarah Nov 20, 2007
    i hit the reset button and it still says waypoint memory full am i supposed to leave it off for a specified amt of time after i hit the reset button?
  • Anonymous Dec 27, 2007
    memory full
  • Anonymous Nov 03, 2008
    Same issue updating software seemed to work
  • dange548 Apr 01, 2009
    starting up my streetpilot c550 it says: memory full.
    after calculating a route it says "route waypoint memory full".
    and it doens't calculates routes anaymore
    Sniper:
  • 50 Answers
Hi, Please do not shoot the messenger (me) but this is a known problem with Garmin GPS units. According to Garmin Tech Support, this only occurs on Garmin units with older firmware. (Personally, I am not convinced this is actually true. I no longer have my Garmin C550, which I personally liked the best out of all the GPS units I have owned or used. I will buy another Garmin, probably a Nuvi, when this silliness sorts itself out.) Anyway, you have two options, neither of them acceptable to most people, including me. 1)Perform a HARD RESET which will wipe out all data on your unit, including your favorite points, Bluetooth connections, and almanac data (satellite information). Your unit will then need at least 40 minutes, with a clear view of the sky, to update the almanac and reacquire its location. To HARD RESET, unplug your C550 from the charger and turn it off. With the C550 screen facing you, press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER. You need hold both constantly for at least 30 seconds. Follow the instructions on the screen. See if any of your personal information is still there. If there is none, then you might as well perform Step 2 below. 2)Download and Load New Firmware onto the C550. Upgrading firmware is relatively easy provided you have a computer. Visit Garmin's website (www.garmin.com). Go to "Support" .. "Updates and Downloads" and then click "Unit Software." Download the software called WebUpdater. Run that and follow its directions. The new Firmware (Software that is loaded into internal memory that does not need power to remember the information) hopefully will fix the MEMORY FULL problem. Good Luck and please post back if the fixes helped or not. I really want the new firmware to work so I can buy another Garmin.
Posted on Oct 06, 2007
Cannot Calculate the route - Garmin Nuvi 3760
My probleme:
When you want to select (established) a route (Finding Location or Planing a Trip) the device machine can not calculate route and displays the following message: "Route waypoint memory is full". The device is Garmin 3760T.
I found the solution:
1. Start the device.
2. Touch "Wiew Map or Map"
3. Touch on bottom right of screen (Speed)
4. Hold your finger on top center of screen for 5-10 seconds (the speed semicircle between Trip A and Trip B). The unit would go into "Diagnostic Page".
5. Select "Clear all user data" and confirm.
Warning: will erase all user-selected data (Home, Recently Found, Favorites, Trip Planner, ....).
Mar 04, 2014 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
Garmin C550Calculates route and then powers off
Hello.
You can go to mygarmin.com or garmin.com . You have to register. It is for FREE. Then,you can update your GPS. You can also download maps by just following the screen instructions.
You can also find all the software/drivers you need there.
Hope it helps.
Apr 19, 2010 | Garmin StreetPilot c550 GPS Receiver
Help I my nuvi navi says it doesnt have maps???? SOS
garmin are preloaded with maps for routing, never the less, you need to backup with software from www expertgps.com/gps-receivers/garmin-nuvi350asp OR drivehp.com/backup. your set may work after doing that. thanks
Mar 19, 2009 | Garmin Nuvi 350 Car GPS Receiver
No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
Memory full error
power off the GPS, then press power button to power it on, press right-bottom corner of the screen during it power-on, will pop-up a button on screen let you to clear user data.
Jan 20, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin streer pilot c550
i had a simalar problem -i asked for an update off garmin and they sent me a disc with apdated maps but didnt tell me i had to first delete the loaded maps you will have to go on the garmin website and order the FREE update disc for uk and ireland and just follow the instructions when you recieve it hope it works for you ;>)
Aug 27, 2008 | Garmin StreetPilot c550 GPS Receiver
Can't find State or Province
The C550 does support USB 2.0 so data transfer of the Maps was most likely faster. The newer USB drivers from Garmin is most likely USB 2.0 compliant. Perhaps they didn't fully test it for USB 1.1 Anyway it's working for now. Usually I go to setting Map, Map info to verify that the upgrade was successful.
Jan 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
1,691 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
