Question about Acer Aspire 5100 Notebook
No mouse controll
The built in mouse nor an external usb mouse will let me controll actions.
    Sergeant:
  • 457 Answers
I saw you a minute ago requesting assistance via "Let our Experts Solve your problems" we are bound as Experts to ask for a payment when people require assistance in this manner. Goodness knows why you didnt wait until someone answers you. Your problem with your mouse is to reinstall the drivers. The USB mouse must have come with a driver so install that else look here for the driver. http://drivers.myfreewares.com/driverdownload.php That is all your problem is, its a software one.
Posted on Oct 05, 2007
SOURCE:
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
How do I turn off the automatic scrolling feature? a mini scroll bar appears on the page and my attempt to move the cursor instead moves the page up and down. Most annoying. I've tried the scroll button...
what OS, XP? operating system? is it?
using only one mouse? the built in mouse pad or it and a plugin mouse at USB port? or external wireless mouse.
we cant see what you have there, nor what are are using now.
if the PC is not infected.
click control panel, the click mouse icon there, bingo change mouse actions.
or reload the HP mouse driver.
Sep 14, 2017 | HP 6530b Notebook
I have acer laptop model ASPIRE 5732Z suddnly inbuiled mouse stop working but usb mouse is working, whats is the problem and what is the solution.
There is sometimes a switch to disable the built in mouse/trackpad when using an external mouse, you can also check mouse properties in control panel
Jul 10, 2010 | Acer Computers & Internet
The mouse on my laptop doesn't work, but the external mouse plugged into the usb does. Any suggestions?
Touch Pad setup with the usb mouse installed for easy navagtion
check the device manager for mouse mouse and other devices
look for nthe touch pad label
look see if it is running ok and enabled.
Make sure it is.
Go to control panel open the mouse icon
touch pad mouse properties
Here is where the controles for external and internal mouse settings will be found.
The rest is up to you
Jun 26, 2010 | Toshiba Satellite A100-S8111TD Notebook
My logitech game pad shifts my mouse pointer erratically
Hi, This seems to be a USB bandwith issue, do you have printers, scanners, external HDD connected to your computer ? If yes please unplug them and see if it works better. If not, try only to unplug the Dual action, and see, if it stops behave this way, then you might want to uninstall LGS and reinstall it.
Thanks and have a nice day J -
May 03, 2010 | Logitech Dual Action for Pc (963292-0403:)...
Mouse and Keyboard are dead
plug in an external keyboard and mouse the  go to the control panel click mouse the select the built in and click enable go back and do the same thing with keyboard
Jul 13, 2009 | Computers & Internet
Dell Studio 15 laptop mouse does not work at start up.
It sounds to me like the mouse buillt into your laptop is conflicting with the Dell external mouse. If you go into control panel and click on mouse, you can disable your built-in mouse. Restart your computer with the USB mouse plugged in and see if that does the trick. I would be surprised if it does not. On the off chance it doesn't work, you will have to enable your built-in mouse and we can check to see if there are any additional conflicts happening through your hardware profiles in the system area of control panel.
Jun 21, 2009 | Dell U0636 Mouse
No cursor control
U may have to reinstall ur touch pad driver
otherwise use external mouse and then check it out
otherwise uninstall ur touchpad drivers then install it
Jan 20, 2009 | HP Pavilion dv6000z Notebook
Acer Aspire 5100 Notebook Logo
47 people viewed this question
Ekse
Alun Cox
