Question about JVC Sirius KD-G400 CD Player
Jvc kd-g400 i kind of know how to fix my radio just need some one to help me, its regarding the fact that my radio can't tune to local stations it only works in odds. i have taken all other methods but the thing im looking vor is that you press 2,3 or 4 buttons just don't know wich ones or for how long, if you don't know then don't bother I KNOW IETS A 3 OR 4 BUTTON PRESS !!!!
  • voltenator Oct 08, 2007
    i have the anser, You hold select or Fm/Am Button + button 5 for 3 sec then the disply says earope and iets done
How to set the clock
Posted on Mar 18, 2008
SOURCE:
How do i set the radio stations on my jvc kd-s26 radio
1. Tune to the station you want to set the preset to.
2. Short-press the "menu" button.
3. Using dial, select the preset you want to set it to.
4. Long-press the dial to store the preset.
Jul 16, 2012 | JVC KD-S26
I cannot tune the radio to lots of local stations , most of them with even frequencies (such as 88/0, 91.8, 104.0 etc. The tuner stops only at odd numbers and at only selected stations. It is also very...
The only thing I could find in the manual that might possibly solve this problem, is a "reset".
From the manual:
Press the reset button on the
panel holder. (The clock setting
and preset stations stored in
memory are erased.) (See page
2.)
You can get a copy of the manual here. I hope this helps and good luck. Please rate my reply - thanks.
Jul 12, 2011 | JVC KD-SX770 CD Player
I can not tune on even fraquencies
Thats USA tuning, you can only get those odd stations on that deck.
May 30, 2009 | JVC KD-S5050 CD Player
JVC KD AVX1 car stereo will not tune in to any radio stations, just keeps searching for them, can hear de tuned stations badly. All connections are ok. Any suggestions? Thanks
standard problem would be antenna issue. Make positive that the connection in the rear of the unit has a connection. If it does, take it out, slip a single, small wire in the back of the smaller hole [typically 1 ft long]. Although this results in an impedance ,ismatch, it will allow you to see if the antenna is at fault. With the wire in the hole, scan through the channels. Fixed? Antenna issues. Not fixed? You have an electronic circuitry or setup problem. Try the 'local' and 'mono' switch with the real antenna still connected. Still no reception?
This becomes an electronic issue at this point which stems at the following concerns:
impedance circuitry [usually small, diode at output]
PLL IC faulty or no V
Oct 15, 2008 | JVC Car Audio & Video
Cannot tune to local stations
- The 0.2MHz odd steps are standard for US radios. Try resetting the radio (recessed button under the front panel) If this a US radio then this may not help. If you have lost the manual then go here:- http://books.jvcservice.com/booklist.asp?Model=KD-G400 Come back and say if this helped or not, I could dig a bit deeper.. -
Oct 04, 2007 | JVC Sirius KD-G400 CD Player
Tuning station problem
Try this: "Hold FM/AM and Press #5". This solution is for a different model JVC stereo, but hopefully it will work for yours as well.
Mar 25, 2007 | JVC KD-S5050 CD Player
JVC KD-G400 Radio reciever
I'd go to their website and download the owners manual and see if that tells you how to do it. Good luck.
Jan 15, 2007 | JVC Sirius KD-G400 CD Player
JVC Sirius KD-G400 CD Player Logo
164 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
