Question about Hitachi 50EX20B 50" Rear Projection Television
Hitachi resistor value
I need values for resistors r1363, r1364, r1338, & r1339 for a Hitachi 50ex20b. New STKs but no control of any color at the board or remote. thanks
  • lulu69 Oct 06, 2007
    oops, this is for a 50ex12ba.
    President:
  • 4,402 Answers
Http://www.eserviceinfo.com
Posted on Dec 05, 2007
What's the value of resistor RK42 on the Hitachi 57F500A?
3.3 ohm/ 1 watt / metal oxide. HIT p/n: AT03202S -- red hor. conv. -- from IC ik04 (STK392-110/150)
May 03, 2010 | Hitachi 57F500 57" Rear Projection...
How do I locate resistor values?
Click HERE to download service manual copy for free. Download all 12 files and unzip with winrar to get pdf file.
Hope this will help you to find out required resistors value.
Oct 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Tv does not turn own, red power button just flickers
Replace your STKs they are big black ICs will have part # on them STK392-110 if 110s use 150s better ICs also you need to CK small ohm resistors rk42 rk48 rk50 rk52 rk56 rk58 rk62.I will have to get back to you after i find correct value of resistors.
Sep 18, 2009 | Hitachi 46F500 46" Rear Projection...
Pioneer SD533HD5 Convergence Issue
All the values and resistors are part of the Hitachi kits on www.TvRepairKits.com
Mar 09, 2009 | Hitachi 43UWX10B 43" Rear Projection...
CONVERGENCE
Check for bad resistors low ohms near your STKs big black ics.
May 04, 2008 | Hitachi 50EX20B 50" Rear Projection...
Need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Mar 24, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Convergence pots do nothing
Check B+ sources--possible open fuse device== that will cause out of alignment/no control.
Oct 02, 2007 | Hitachi 50EX20B 50" Rear Projection...
Colors all messed up
The fact that you used the term "magic focus" tells me you have a Hitachi projection set. When the colors no longer line up on a Hitachi projection TV, it means that most likely one of the convergence output IC's has shorted out. Sometimes a shorted convergence output IC will burn up a low value resistor too. I have also seen a convergence IC crack loose from the board and burn up 3 low-value resistors. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The output IC's should be resoldered / replaced and the circuits checked and realigned by a qualified tech familiar with Hitachi projection sets.
Sep 09, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Aug 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
