Question about Baby Gear
CLK 330 seat malfunctions
I have issue where seat won't move forward and back. I can move the lumbar and seat up and down, but can't adjust forwrd and back
  • Anonymous Feb 19, 2008
    I have the same issue... Try resetting the computer.. Pull the negative battery cable off for 30 minutes..
  • Anonymous Mar 30, 2009
    I have the same problem, other functions work, but I cant move the seat back and fort
The solution to your problem is to adjust your leg length instead.
Posted on Jan 02, 2008
SOURCE:
DRIVER POWER SEAT LUMBAR BUTTON STUCK. SEAT DOESN'T MOVE
Remove the button & resolve that part of the issue,
so it either works or if tests bad-- replace it
Dec 07, 2012 | 2010 Chevrolet Silverado 1500
GMC Yukon Seat Switch
You don't mention what year your Yukon is ? This could very well be a control Module problem .
I'll post how the power memory seat's work or are suppose to work !
Memory Seats Description and Operation
Battery voltage is supplied to the memory seat module through a 25 A circuit breaker. The memory seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch common circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the memory seat module the switch status is active. Each seat adjuster motor is controlled by the memory seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the memory seat module. The memory seat module operates the seat adjuster motors by switching one of a motors control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the memory seat module and are used to determine the seat position when storing or recalling memory settings. The driver seat adjuster motors use potentiometer type position sensors. The position sensors are supplied with a 5 V reference and ground circuits from the memory seat module. The position sensor signal circuits return to an analog input within the memory seat module. During adjuster motor operation the position sensor provides a voltage change proportional to the change in revolution of the adjuster motor shaft. The memory seat module monitors the voltage from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver door provides inputs to the driver door lock/window switch. Battery voltage is supplied to the memory recall switch assembly from the driver door lock/window switch. When a RCL 1, RCL 2, or EXIT switch is pressed, the switch contacts close the appropriate switch signal circuit to the battery voltage supply circuit within the memory recall switch assembly. When the driver door lock/window switch receives active switch signals from the memory recall switch assembly, the appropriate commands are sent to the memory seat module using the GMLAN Serial Data circuit. The Body Control Module software version determines the personalization features available.
Memory seat recall operation is allowed only with the transmission selector lever in the PARK position while the ignition is on. The transmission selector lever position data is provided to the memory seat module by a message through the GMLAN Serial Data circuit.
There are somethings listed you are not familiar with , like GMLAN Serial Data circuit ,maybe Body Control Module software etc... GMLAN is a communincation network that the computers on the vehicle uses to share information , transmit commons etc... you can google it to read about it .
There are DTC'S - diagnostic trouble codes that can set in the module in control . Do you know what DTC'S are .
DTC Descriptors
DTC B1825 01: Driver Seat Recline Position Sensor Circuit Short to Battery
DTC B1825 06: Driver Seat Recline Position Sensor Circuit Short to Ground or Open
DTC B1825 5A: Driver Seat Recline Position Sensor Circuit Plausibility Failure
DTC B1850 01: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Battery
DTC B1850 06: Driver Seat Lumbar Horizontal Position Sensor Circuit Short to Ground or Open
DTC B1850 5A: Driver Seat Lumbar Horizontal Position Sensor Circuit Plausibility Failure
DTC B1860 01: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Battery
DTC B1860 06: Driver Seat Lumbar Vertical Position Sensor Circuit Short to Ground or Open
DTC B1860 5A: Driver Seat Lumbar Vertical Position Sensor Circuit Plausibility Failure
DTC B2355 01: Driver Seat Front Vertical Position Sensor Circuit Short to Battery
DTC B2355 06: Driver Seat Front Vertical Position Sensor Circuit Short to Ground or Open
DTC B2355 5A: Driver Seat Front Vertical Position Sensor Circuit Plausibility Failure
DTC B2365 01: Driver Seat Rear Vertical Position Sensor Circuit Short to Battery
DTC B2365 06: Driver Seat Rear Vertical Position Sensor Circuit Short to Ground or Open
DTC B2365 5A: Driver Seat Rear Vertical Position Sensor Circuit Plausibility Failure
DTC B2375 01: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Battery
DTC B2375 06: Driver Seat Assembly Horizontal Position Sensor Circuit Short to Ground or Open
DTC B2375 5A: Driver Seat Assembly Horizontal Position Sensor Circuit Plausibility Failure
5) Memory Seat Module is under the front of the driver seat , you could look under an see if all the connectors are fully seated.
The best diagnostic step would be to hook up the factory scan tool an see what the computer is seeing as far as inputs from the switch an outputs it's sending . I wouldn't suggest you take the seat apart an try testing electrical inputs etc.... unless you very familiar with automotive electrical systems an circuits .
Mar 06, 2017 | GMC Cars & Trucks
Front seat will not slide forward? The seat will move up and down, tilt, and the lumbar works? Even the heated/cooling seat works? What do I need to look for and how do I fix it:?
The power seat in the truck has 3 motors, one of them is not working, the most common cause of this is the power seat switch is defective, it is often the forward and reverse seat positioning switch that fails because it is the one that is most used. If the switch checks ok then you will need to replace the the power seat track assembly, Ford does not sell any parts for the track, it is only available as one complete unit, I know this because i retired form a Ford dealer. Please rate my help for Fixya. Thanks
Dec 29, 2011 | 2007 Ford Expedition Eddie Bauer EL
2003 Buick Regal: how do I hook up the front seat heating system? I think they're just disconnected. I can see all the wires under the driver's side seat. Neither the driver's side seat heater or seat...
The last time I checked one of these, the wiring harness for everything you just described is underneath the seat. You'll have to move the seat all the way forward or back to get to the harnesses to reconnect them.
I hope this helps! :) Let me know if you need any further assistance in this matter.
May 19, 2010 | 2003 Buick Regal
Hi - I have a much loved 2004 SAAB 93 Aero sedan.
This has been happenning on my 2006 Saab 9-3 2.0 T also for about 2-3 months also. I have had no clues until today I learnt by accident that the lumbar support on my car's driver seat does not work anymore. Which means that there are broken strings/wires inside the seat and that move on braking and make clicking sound. I haven't checked my seat's lumbar support but will do soon.
Try your lumbar support adjustment and see if it is moving freely, that means it not adjusting the lumbar support. If that's the case, that may be the cause of the clicking/slight-movement of the seat.
May 09, 2010 | 2004 Saab 9-3
Driver's seat stuck. Lumbard support works,
HI. There are only two causes for this particular issue. The most common will be a failed switch assembly. This should be located on the side of the drivers seat. This switch is responsible for transferring the movement commands to the actual motor/gear assembly, which is located on the rail structure under the seat in question. If your lumbar section is responding to commands, but the others fail, this will lead to a failed switch circuit. the entire switch board will need to be replaced, in this case.
Now, if you command the set to move forward, and all you hear is the motor running , but no movement, this will lead to a failed gear assembly. This will be the second cause of no forward/backwards movement. In this case, the entire motor/gear assembly will need to be replaced, due to the fact that the gears are not sold separately. The are shipped as a kit with the motor.
It is required that you order this type of replacement part directly from the dealership.
  • NOTE_ I have seen in most cases that the there was jam, due to pieces of the gear assembly breaking off, and jamming up the mechanism. in order to properly inspect for damage of this nature, it will be necessary to remove the seat.
Mar 26, 2010 | 2002 Mercury Mountaineer
HOW TO ADJUST DRIVER'S SEAT IN HYUNDAI ELANTRA
There is a lever on the left side by your **** that tilts the seat forward or back. There are knobs on the side that you turn to raise the seat front up or down, there is a handle under the front of the seat that you either pull up or pull to the left to slide the seat front or back. And depending on the seat there might be a lever on the left side of the seat back that controls how much lumbar support.
Feb 02, 2010 | Hyundai Motor 2003 Elantra
Horn and power seats quit working. maxi-fuse extremely hot. pulled it out and re-inserted after it cooled down. fixed the problem temporarily (a day or so). swapped that maxi-fuse with the one above it...
which maxi fuse gets hot ? # fuse , plus amps The power seats uses a 30 amp circuit breaker ,not a fuse . The horn gets power from the same circuit breaker . . Sounds like something is drawing to much current. Do you know how to use a amp meter to test current flow . Disconnect componets till draw goes away ? How to use a wiring diagram to pin point areas in a circuit to test ?
Is there corrosion on the pins where the seat circuit breaker plugs into ? Reach under your seats an see if one of the seat motors is hot .
DeVille
The left and the right power seat system consist of the following components:
• The seat switches
• The seat relay modules
• The 4 reversible motors:
- The front vertical motor
- The rear vertical motor
- The horizontal motor
- The recline motor
These 4 motors operate independently of each other.
When the entire seat switch is pushed to the FORWARD position, the forward input of the of the seat relay is grounded.
The seat relay module supplies battery positive voltage (B+) with a ground to the horizontal motor, in response to this input. In order to drive the seat forward, the motor runs until the switch is released.
The BACK position works similar to the FORWARD position with the exception that the voltage polarity supplied by the seat relay module is reversed causing the motor to run in the opposite direction. This action drives the seat backward.
These recline switches operate similar but independently:
The seat relay module could be bad , If you don't know how to do automotive electrical circuit testing it mite be a good idea for you to take your vehicle to a qualified repair shop.
Could have diagnostic trouble codes stored as well .
DTC B0846 +5 Volt Reference Out of Range
DTC B0856 Battery 2 Out of Range
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1982 Source/Battery Voltage High
DTC B1983 Source/Battery Voltage Low
DTC B2101 Recline Aft Switch Failed (Eldorado)
DTC B2101 Recline Aft Switch Failed (DeVille)
DTC B2102 Recline Forward Switch Failed (Eldorado)
DTC B2102 Recline Forward Switch Failed (DeVille)
DTC B2103 Rear Vertical Down Switch Failed (Eldorado)
DTC B2103 Rear Vertical Down Switch Failed (DeVille)
DTC B2104 Rear Vertical Up Switch Failed (Eldorado)
DTC B2104 Rear Vertical Up Switch Failed (DeVille)
DTC B2105 Horizontal Aft Switch Failed (Eldorado)
DTC B2105 Horizontal Aft Switch Failed (DeVille)
DTC B2106 Horizontal Forward Switch Failed (Eldorado)
DTC B2106 Horizontal Forward Switch Failed (DeVille)
DTC B2107 Front Vertical Down Switch Failed (Eldorado)
DTC B2107 Front Vertical Down Switch Failed (DeVille)
DTC B2108 Front Vertical Up Switch Failed (Eldorado)
DTC B2108 Front Vertical Up Switch Failed (DeVille)
DTC B2109 Lumbar Aft Switch Failed
DTC B2110 Lumbar Forward Switch Failed
DTC B2111 Lumbar Down Switch Failed
DTC B2112 Lumbar Up Switch Failed
DTC B2115 Recline Sensor Failed
DTC B2116 Rear Vertical Sensor Failed
DTC B2117 Horizontal Sensor Failed
DTC B2118 Front Vertical Sensor Failed
DTC B2119 Lumbar Forward/Aft Sensor Failed
DTC B2120 Lumbar Up/Down Sensor Failed
DTC 2130 Seat Motor Failure
Aug 10, 2017 | 1997 Cadillac DeVille
Driver seat back won't raise after its been reclined
The control switch has developed a problem (intermittent contact or just broke inside) Replace the switch. That should fix it.
Jun 14, 2009 | 2007 Hyundai Santa Fe Limited
2002 chevy trailblazer
This could the motor problem in the power seat the forward motors may defective get it changed and it will slide................
Jun 04, 2008 | 2002 Chevrolet TrailBlazer
Baby Gear Logo
260 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
