Question about Intel Motherboard
Black screen after start up
Hi I tried to add memory to board and got black screen on pc, so I reinstalled old memory back in and same thing. Was wondering if you could tell me of a better mother board to get that is compatible to this one. I have a 256 graphics card I can install from ATI it is PCI.My system is an Insignia 400a desktop with vpr matrix,2.8ghz Intel 4 pentium,512mb ddr sdram. TYVM sandman2k1
    Problem Solver:
  • 10 Answers
Try this: 1- remove your graphics card 2- Remove your RAM dimms 3- remove the battery from CMOS 4- remove the power cable 5- try and power your computer so he actually runs out of electricity still in the condensers. 6- with a rubber, gently but firmly, rub the contact pins in your RAM and your Graphics Card 7- with a brush, remove any dust that there might be on the both RAM slots and Gaphics slots (AGP r PCI-EX) 8- Plug it all back in (battery, RAM and Graphics Card and power cable) 9- Boot your system normally 10- check me back just to know if it worked. my Regards -Pedro Silva
Posted on Oct 07, 2007
Basically any board that has a pci slot will let you use your ati card
Posted on Oct 06, 2007
Just tried to add memory. Initially gave a blue fault screen. took new memory out and put old back in. Now computer freezes prior to just opening desktop. Can not start in safe mode. Same thing...
Hello tlp7
Probably the slots need a good clean up . Use a soft cloth or a brush with methanol or similar to get them
spotless and clean the old memory pins the same way . Ensure your new memory card is compatible with your system .
Best regards ,
fanaudi .
May 14, 2011 | HP Pavilion a830n (PP166AA#ABA) PC Desktop
I have a S4020WM. I installed a new video card. The computer was running slow and my Start Menu task bar was missing. I rebooted the computer and ran in safe mode. I shut down the computer. The next time I...
i cant understrand how you got to VGA card
PC ran great before but not after card stuffed in
nor if PC had a card before, then changed it a different card
Some PC have VGA chip on board and need no card. for VGA.
onboard fails, or it and the existing card fails the add 2nd card and it fails.... there is story here you never told.
The OS is corrupted.
reload, XP.
XP is a virus magnet, id up graded it.
but if you love danger.
there is only 2 ways to restore.
1: the F10./F11 restore key
I first carbon date pC, ,after age matters, things go obsolete fast.
so. how old is the beast. real name.
Compaq Presario S4020WM this pc is 100% RETIRED< zero support by HP
i found, that it does have onboard VGA 15pin jack
center of read MOBO.
so do both fail>???????????????????????????
try some install disks to reinstall the os
try F8, yes, F8 dead, means the OS is corrupted
needs OS reInstalled, for sure.
buy the disks from HP or 3rd party
Mar 22, 2017 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Hi my original problem of black screen turned out
Well... if your target is the motherboard replacement (and nothing else is going wrong except of your motherboard),
you don't need to reinstall the OS again (op hard disk).... if your new motherboard is axactly the same brand/model as the old one, nothing more you need to do, but only the to replace the old motherboard by the new one!!!
Apr 14, 2011 | Acer Aspire M5641 PC Desktop
Computer is on but blank screen
Check the RAM .
If the problem is same . remove the cmos battery and install again.
Reply me soon.
Hope this help.
Feb 19, 2011 | Intel Motherboard
Screen stays black and have to shut down and restart, this happens 2 to 3 times per week.
With no more information that what you have provided I would start by reseating the memory and video card if you're not using onboard video. Then I would check the hard drive via chkdsk, run it from a command prompt. If the drive seems ok the next thing I would do is reinstall the OS. If it still gives you trouble after that you have a faulty component (memory, processor, power supply, video card, or mother board) and I would start swapping in known good components.
May 23, 2009 | Acer Aspire Computer - Intel Dual Core PD...
Black screen
unplug evry thing and check out the cmos battery on *********** board .remove that cmos battery and reinsert that.also remove the ram (the memory)from the mother board and refit it properly and then reconnect every thing as it was and start the pc it will work.
Feb 26, 2009 | E-Machines eMachines Desktop PC
''error loading operating system'' on Nec Versa laptop.
First if you haven't already unplug the power and take out the battery for a minute or so. Then reinstall the battery and connect power. Then try and start in Safe Mode, To do this start consistently pressing and releasing the F8 key while pc is powering on, continue until screen should display a similar screen as when turning on normally. From there ( hopefully it has started up ) you should be able to go to START MENU> click/open Control Panel> click/open ADD OR REMOVE PROGRAMS and start removing any programs, if not all, that look like they are using a lot of memory. Doing the SYSTEM RECOVERY is going to uninstall EVERYTHING and reinstall it anyway. Also remember you can only have one security program running other wise they will conflict with each other and cause numerous problems.
Clear temporary files and browsing history. Open IE, even if you don't ever use it, open TOOLS> open INTERNET OPTIONS> In the BROWSING HISTORY section click DELETE > Then click DELETE ALL
One other thing you may want to do is START MENU> RIght click MY COMPUTER> click PROPERTIES> click ADVANCED> click SETTINGS in the PERFORMANCE box and select 'LET WINDOWS CHOOSE WHAT'S BEST FOR MY COMPUTER'
Hope this helps.
Nov 18, 2008 | Computers & Internet
Emachine t5206 adding 2 gig of memory
How much memory are you trying to add?
Nov 08, 2008 | E-Machines eMachines Desktop PC
Partial bootup
it seems to be a defective card since one of my old graphics cards was defective and had the same problem. Also, try reinstalling the graphics drivers.
Oct 09, 2008 | ATI RADEON X1650 Graphic Card
HP Pavilion dv6000t will not reboot after installation of added memory. Produced a series of "beeps" one time only, but not again.
click start
right click my computer
device manager
scan for hardware changes
Aug 30, 2008 | HP Computers & Internet
Intel Motherboard Logo
94 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
